Hey guys,
I have located more spare parts that I have purchased and ended up having spare which need to go.
1. Genuine HPI Engine Damper Kit - BCNR33 - New
Helps prolong the life of your engine mounts by reducing wear due to excessive engine movement. A worthwhile addition for any modified GTR
$230
2. Nismo Billet Oil Cap - New SOLD!
Suitable for Skyline, Silvia etc
3. Nismo Veruspeed Oil Filters - Suit S14/S15 (x2) - New
Each Nismo Veruspeed oil filter offers 21% less pressure loss, 24% increase in filtration, 10% less flow resistance, and 37% increased life.
$45 Each
4. Nismo Veruspeed Oil Filters - Suit RB20/RB25/RB26/CA18 (x2) - New SOLD
5. Nismo Racing Fashion Lighter - Used SOLD!
Speaks for itself really - For the Nismo junkie :)
$15
6. Length Of Braided Hose - Unused
I have a significant length of stainless braided hose which I never ended up using - Pefect for radiator hose etc.
$50 (Pickup only)
7. R33 GTR Factory Mats Set - Used SOLD!
Completed 5-piece genuine R33 GTR mat set - Very good condition - Hard to find
$200 - (Pickup Only)
8. R33 GTR Factory Cams - Used
Removed during engine build - No longer needed.
$150
9. Trust Polished Single Turbo Inlet Pipe (Y Pipe) - Used SOLD!
Genuine Trust single turbo inlet pipe (Y Pipe) completed with silicon joiners and hose clamps. These pipes are extremely hard to come by and this one took me a long long time to locate.
The Trust inlet pipe for single turbo setups facilitates the use of twin Z32 type air flow meters in conjunction with a single turbo setup and comes nicely polished.
$200
10. R33 GTR Factory ECU - Used
$250
11. R33 GTR Washer Bottle - Used
Replaced with oil breather tank - No longer needed
$40
12. R33 GTS-T Washer Bottle - Used
No longer needed
$40
13. RB25DET Coil Pack Cover - Used SOLD!
No longer needed
$40
do you know if the cams would fit a 33gtst and would the be any lumpier, or bigger lift
Honestly not sure on that one - I know of RB26 cams being used in RB20's as an upgrade but when it comes to using them in an RB25 it would be worth checking with your mechanic.
GTR cams in GTS25t is a no go. Get nothing under 5000rpm due to compression loss. You also lose VCT on the inlet but if you are happy to lose that then they are perfect for a regrind at Ivan Tighe Engineering Brisbane for extra lift.
Disappointed Nick. Nothing I want mate.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
