  • Replies 249
Wow that looks really nice actually..
Are they gram lights? If so those rims arent cheap at all..
Btw you got any pics from the rear?
Just curious to see how the gtr wing looks like..
if you dont like it, we can do a swap?? money on top to you offcourse!! hhehe
Nah not gram lights..
The rims are 18x8 fronts and 18x9 rears
Dont have any recent pics from the rear... only when my car was a fresh import...
Wouldnt ever sell my gtr wing.. I love it.. makes the car look so much better
Rims are RTG.. And they are like a Dark brushed alu colour.. Got them 2nd hand off here.. Recently found out to replace they are around $350 per rim
So pretty happy i got them for $900 with near new tyres
They also have a slight dish hidden behind the spokes... Absolutely love them.. but had to get the rear guards rolled to accomodate
A few happy snaps of my R33
The wheels are GMAXX 18" , the front are 8.5 wide (225/40/18), rear 9.5 wide. (265/35/18)
i will try and get newer pics over the wkend
aw man...da best color scheme rim ever for a silver colored car......
seriously seriously beautiful
  • 4 weeks later...
Cheers for the pics dogknight.. looks great!! more lowering will help too :laugh:
Here are some pics of my new reprayed p1s.. Sorry about the quailty.. Couldnt use my friends camera properly and was taken in a hurry lol
Will post more pics later on.. photobucket is so slow :)
Edited by siddr20
Woot got better pics.. will post them up soon.
Like the gunmetal? spray painted them myself..
very proud..
lol
Yup the gunmetal looks great ,suits the car really well :pirate:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
