A private day for Skylines is unobtainable. The wont reply to phone messages, emails or letters.
WSID is run by a bunch of people who only care about V8's and top fuelers.
That said, if we didn't own Skylines we could get a private day for $10,000 with a list of rules and requirements that are practically impossible to comply with.
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2533051
  • Replies 78
Now now Adam, settle down champion. I'm sure that in a decade or two we'll be sweet with WSID. :O
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2533157
But isnt there another drag place that can be used? or is WSID the only place? :O
not in nsw there isn't. or are you proposing we travel to another state/country for a drag day?
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2533353
I was actually in talks with the guys there,
said needed 40-50 cars and around 200 each
no under 11 second cars.
but needed to be booked months and months in advance
Long story short, don't bother. At least not on our behalf. Seriously.
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2533480
Congrats to Mr Dinzlr on the 11.0, 10.8 and 10.9 passes thats 1 top sounding GTR!
Well done, Din. ;)
What was the mph?
Oh, btw Baron, I know why Ben goes to every WSID event ever held....and her name's not Wendy ;)
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2540832
128, 128, 132.5mph from memory.
Mik got down to 11.2sec @ 128mph also from memory and afew GTS-t's from here doing 14's. Also Caz in the 300ZX did a mid-low 13sec in amongst all the other 300's out there.
No her name definitely isn't Wendy although she still melts in my hands.. ;)
https://www.sau.com.au/forums/topic/136227-wsid/page/2/#findComment-2540841
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
