Hey folks just after some advice here, I am struggling to figure this one out!
I recently installed a Blitz DSBC Spec S Single Solenoid boost controller on my car (R33 S2).
The car is standard with a 3" exhaust/ dump pipe & pod filter.
After setting the desired settings (NORMAL 0.5 bar HIGH 0.7 bar) I noticed the boost spikes dramatically (to approx 0.95 bar) during vigorous gear changes. The boost stabilizes a split second after a gear change has been made.
I have managed to reduce the severity of spiking by lowering the boost warning setting but this just leads to jerky power delivery as the boost controller tries to constantly correct boost during gear changes.
Strangely, when the boost controller is switched off this spiking still occurs.
How can this be cured?
This boost controller does NOT offer GAIN or boost response settings?
Any suggestions or help is welcome. Thanks guys!
https://www.sau.com.au/forums/topic/136871-spiking-like-crazy/
I had a spec s boost controller on my skyline (r33 s1). I was told that once you go over .7 bar the boost solenoid needs to be upgraded($110). I think its even written in the operating instructions. I tried to run mine at 1 bar and it just went stupid, spiking to 1.5 bar. So i got rid of it.
I am currently using the non standard Blitz Solenoid that was bundled with the boost controller.
The factory Nissan one has been removed. It's puzzling... When I turn the Blitz controller off it runs 0.5 bar (standard). However if the car is pushed harder i.e. quick gear change it will still spikes!
What are Blitz Boost controllers like as a general rule??? Are the problematic?
Hey guys, any more ideas with this one???
Surely someone else out there has had similar troubles.
Cheers.
just out of curiousity, where is the pressue hose run from? is it run from the bov hose is it? possibly done when fitting a front mount cooler.
i had spiking with my $22 controller after i did my cooler install. i had the hose hooked from the bov hose (like it shows in the instructions). this caused spiking on gear changes. i moved the hose to the 'hot' cooler pipe (took the nipple off the old cooler pipe and stuck it on the hot pipe). this solved my problem.
The boost controller pressure hose taps into the fuel pressure regulator or the small vacuum hose coming out of the front of the plenum chamber.
I also have a mechanical boost gauge tapping into this same location. Do you think I should relocate the boost pressure line?
The pressure hose for the boost controller itself is small in diameter. Approximately the same size as the factory vacuum line exiting the back of the plenum... :laugh:
so the hose is rather long? i would relocate the pressure line to before the cooler. that way the hose will be nice and short. and it also won't suffer spiking due to cold nights.
you will find that companies like HKS have the wastegate line coming off the compressor side of the turbo.
Cheers for the advice mate! I might have to redo the hose set up in this case...
umm i got the same boost controller.... and it definetly offers set/gain settings....
you sure u read the manual on howto set it up properly ?
sounds like you havnt entered the 'set' value correctly..
btw, lemi know if you need the manual for it (took me ages to find online)
i run mine on 12psi, has no spiking issues....
i think the limit is 16psi for the spec-s, not .7 bar
The Blitz I have only has a single solenoid (Spec S version).
The manual I have is in Japanese so its not much use to me :laugh:
My high boost setting is set for around 10psi but it spikes well above this (approx 13psi)
When I toggle the controller (left mode button) I don't have a gain function.
If you could post up the manual you are referring to that would be great!
Thanks
change menus till you get to the 'set' screen. then press and hold down "mode" for a few seconds, that will change to the gain value and let you change it.
for my r33 gtst, i have 11 / 48 values. Which gives me a tiny bit over 12psi.
Thanks
SBC_SPECS.pdf
Ahh thanks mate, you are a gent :(
Hey Justin,
I have now found the GAIN setting thanks heaps!!! What GAIN setting do you suggest? What do you run?
I have a stock turbo, standard cooler & 3 inch exhaust.
i use 11 for my gain.
try something like that... yours is probably on the default setting of like 30 or something >_<
Hey Justin,
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
