after DC, sega decided that they are going to be a software based business, coz they always released their systems out so early b4 other companies that the others had more time to use later technology and just got thwarted in sales.
thats why you will see on nintendo game cube sonic games and such hehehe
virtual tennis f**kn rocked! so did snk vs marvel 2
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3325
Virtual tennis is f**ken awesome.
I got Capcom Versus Marvel 2 and that is f**ken awesome too.
Metropolis street Racer is awesome too. have you heard the sound track for that? Awesome real singing voices.!!!
Sega Dreamcast Rocks and if you go to any video game forum everybody says the same thing!
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3326
yeah its pretty cool but i think sega have made a smart move by sticking to software not hardware
i mean...its the games that make the dreamcast so cool
so instead of wasting money on making the hardware that wont sell as well as the competition...they make games for the competition
i knew that one day sonic and mario would join together to kick all ass to 'da shiznat'
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3327
It's pretty awesome with Sega, i mean, they shit over Nintendo (I don't care how old you are) and Sony as far as in house developers go.
And because you're all such big sega men, here's a nice little suprise for you all.
[i:8619c7da92]From specialreserve.co.uk:
The world loves Sega. and when Sega release games, the world listens. With that in mind, sit down, be quiet and envelop the goodness you see before you - all of these games will be on show at the E3 Expo in LA later this month:
F355 Challenge (PS2)
GunGrave (PS2)
Sega Bass Fishing Duel (PS2)
Shinobi (PS2)
0
Super Monkey Ball 2 (GC)
Phantasy Star Online Episode I & II (GC)
Beach Spiker (GC)
Sega GT 2002 (Xbox)
Panzer Dragoon Orta (Xbox)
Crazy Taxi 3 High Roller (Xbox)
The House of the Dead III (Xbox)
ToeJam & Earl III: All Funked Up (Xbox)
Sega Sports Tennis (PS2)
Sega Sports NFL 2K3 (PS2, GC, XBox)
Sega Sports NBA 2K3 (PS2, GC, XBox)
Sega Sports NHL 2K3 (PS2, GC, XBox)
Sega Sports NCAA College Football 2K3 (PS2, GC, XBox)
Sega Sports World Series Baseball (Xbox)
[/i:8619c7da92] SHINOBI GOD DAMN IT WOOOHOOO God save Sega
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3328
Oh man Shinobi is back! yeah baby!
fark I love Shinobi.
I have the arcade emulators to play the original shinobi arcade file.
Yeah when Sega Release! Peopl listen.
Sega is the bomb. I love SEGA. I remember when I first bunged in the sonic 1 cartridge for the megadrive on a nice cold fresh feeling winter night many years ago. Those fantastic memories are so vivd. Its not just about the games with Sega. Its about the Life style and memories that we have of it. Sentimental Values I say.
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3330
:):):D MAN, I've been tryin to tell my mates that DC KICKS ARSE!!!
i love it! i got about 30 games. any of u dudes wanna swap or 'swap' some games sometimes send me a line!
heres the recommendations frmo a dreamcast tosser
1) Soul Calibur
2) Metropolis Street Racer <-- u like cars and dont own this game??? :twisted: ur weird! its THE best! rewards for driftin and everything!
3) Dance Dance Revolution (u need the mat though :) )
4) Jet Set Raido
5) Tony Hawke 2
https://www.sau.com.au/forums/topic/137-sega-dreamcast/#findComment-3336
  • 4 weeks later...
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
