These amplifiers are regarded as the best value amps on the market, the amount you pay, for the power you get AND brand new. We'll we are looking to make them even cheaper for you, by running a group buy on these.
We have secured much better prices than retail, and as always, the more people that get in on the group buy, the cheaper they will be. Pricing will be listed below.
If you are interested, you will need to register your interest and then the full amount will be needed by 31st Oct, 2006. Once this is done, we will order the stock and then distribute it. Pickup is welcome in Sydney and postage can be arranged at an additional cost for interstate buyers.
RRP = $699
1-4 = $550
5-9 = $500
10+ = $450
Attention SPL enthusiasts and competitors! Alas, literally tons of power without having to spend a ton! This award winning Class D amplifier belts out a whopping 1500WRMS @ 1 ohm load! If this is not sufficient for your application, the unit is equipped with a link/strap mode whereby two amplifiers are placed in parallel operation (master and slave configuration) to double the output to 3000WRMS @ 2ohm load!
Utilising only the newest in car audio technology, high quality components are laid out neatly on a double sided PCB. It offers 4 way protection; thermal; over current; speaker short and speaker DC protection to protect your valuable investments. Features to help you achieve astronomical SPL figures are 24dB octave variable low pass filter and subsonic filter as well as an 18dB variable bass boost! Other basic features found on all of our Response range of amplifiers are insert style connectors, low profile stylish heat sink and remote level control.
Specifications:
Power @ 4ohm 14.4V: 800WRMS
Power @ 2ohm 14.4V: 1000WRMS
Power @ 1ohm 14.4V: 1500WRMS
Low Pass Filter: 35 - 350Hz @ 24dB/octave
Sub Sonic Filter: 10 - 60Hz @ 24dB/octave
Bass Boost: 0 - 18dB @ 45Hz
Efficiency: 88% 100Hz @ 4ohm
Dimensions: 434(L) x 258(W) x 50(D) mm
If you are interested, please register your interest here. This will just allow us to keep a better track of all people interested.
https://www.sau.com.au/forums/topic/137222-jaycar-response-1500wrms-monoblock/
already running a group buy on Jaycar stuff for SAU members... feel free to post up what you want :D
http://www.skylinesaustralia.com/forums/in...t&p=2561742
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
