Hey Guy's,
i have a R32 GTST, but i am unsure on what year it actualy is, guy who sold it said 91, rego says 90 and insurance says 93.
I read while back you could tell my the plaque on the firewall depending on what letter was on the end of the sequence.
Does anyone know how i can identify the year?
Cheers
Cameron
https://www.sau.com.au/forums/topic/137264-how-to-tell-the-difference/
Well turns out the car is a 93 model also a type M according to FAST, i downloaded it last night.
The date on the blue plate on the firewall say 1998 and the compliance plate doesnt have a date on it :S
Edited by murrayis
Hahaha.. the 1998 on the blue plate refers to the displacement of the engine :P
lol yea thats what i figured the 1998 was lol, Well put it this way my insurance jsut went up $600 for telling them it was a 93 model, but then again i also told them about the respray, genuine ket, suspension and bigger turbo as well, my bad
When I got my insurance (3rd party fire/theft) I told them bout exhaust etc, which they said doesn't make much of a difference. They said the fact that its 93 increases the premium...cause i had got a quote b4 i bought the car, i used a 1991 r32 gts-t with basic mods just to get an idea and it was a fair bit cheaper than my actual quote for the real car.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
