  • Replies 205
Update...please get to me those who are a maybe as to if your comming or not
People Comming:
JaiJai
R34-GTT
MIVEC
leech_
Amaru
Bluprint
R3sp3ct
SL33KY
low200
SKYLVIA
Shell
chintami
Sinista32
NathR32
Frink
Mr Italy! + 1 ..........maybe??
SkyGTRline.............maybe??
ib6ub9
Psymon
skylinebabe_5
race_snooze
Viper_r32...............maybe??
So everyone kinda forgot about this thread.
We better still be doing it coz i got the boss to agree to let me go an hour early next friday, so i will be able to join you all at 7.30 - and my misses is able to join me also so she'll be rocking up at around the same time.
I dont think the bosses would have a problem parking in the transact carpark but its not for me to make that decision, MIVEC's mum works upstairs so i guess if they get the OK from the suits upstairs then it should be ok - the gates open at night anyways so it should be ok.
So is everyone still on for next friday?
People Comming:
JaiJai
R34-GTT
MIVEC
leech_
Amaru
Bluprint
R3sp3ct
SL33KY
low200
SKYLVIA
Shell
chintami
Sinista32
NathR32
Frink
ib6ub9
Psymon
skylinebabe_5
race_snooze
Viper_r32
Gotta know about Mr Italy and SkyGTRline - will send PMs...
So far we have 20 confirmed names...RSVP is by Wednesday and I'll book it then - So its still on and should be a really good night
Well this is the new list....
JaiJai
R34-GTT
MIVEC
leech_
Amaru
Bluprint
low200
SKYLVIA
Shell
chintami
Sinista32
NathR32
Frink
Mr Italy! + 1
ib6ub9
Psymon
skylinebabe_5
race_snooze
Viper_r32
Veilside R33
So I'll book on Wednesday, and I'll tell them to hold an extra seat or two just incase someone decides that they can come
JaiJai
R34-GTT
MIVEC
leech_
Amaru
Bluprint
low200
SKYLVIA
Shell
chintami
Sinista32
NathR32
Frink
Mr Italy! + 1
ib6ub9
Psymon
skylinebabe_5
race_snooze
Viper_r32
Veilside R33
JaiJai
R34-GTT
MIVEC
leech_ +1
Amaru
Bluprint
low200
SKYLVIA
Shell
chintami
Sinista32
NathR32
Frink
Mr Italy! + 1
ib6ub9
Psymon+2
skylinebabe_5
race_snooze
Viper_r32
Veilside R33
rumble +2
Good so far? This is going to be huge! should have over 25 people - every skyline owner down here!
JaiJai
R34-GTT
MIVEC
leech_ +1
Amaru
Bluprint
low200
SKYLVIA
Shell
chintami +1
Sinista32
NathR32
Frink
Mr Italy! + 1
ib6ub9
Psymon+2
skylinebabe_5
race_snooze
Viper_r32
Veilside R33
rumble +2
CEF11E
Just make sure its all good....cant believe how many people! we'll need the whole frickin store!
