Hey all, got out of work today and what do i find my door handle jammed up(the whole thing) and my lock destroyed. Thank god the little bastards didn't even get into the car but it is going to be a pain in the arse to replace/fix. If i came accross them i swear i would rip off there nuts and make them watch me grind them into mince meat.
Now i have that off my chest is there any place in adelaide that would be a start to look for new one? price?post-15951-1159963160.jpg
https://www.sau.com.au/forums/topic/137328-attempted-break-in/
Sorry to hear about it! You'd be surprised what a crash repairer could do with that .... I had my S15 fixed (had 50% the damage of yours) including respray door for $350. I would ask at Nissan dealers for the actual door handle and lock - should be easy to get (mine was fixable). Expect about $200 for handle and lock I would think.
Thanx guys, i will go see one of my dad's friends tomorrow before work see what he thinks at least you have given me a little hope that it might not be too bad. i'm also going to see if there is video on the carpark. i did find it funny that they hurt themselves in the process and left disgusting blood on my car.
^^^ I'm hearing ya, they touch ma car and i'll touch them! Also another reason to have a daily....... while my line is locked up under a car cover! working arvo shift in Plympton isn't the best place to be driving my car, espesially when i went out for 5 mins a few months back and noticed when i came back there was a car on fire down the end of the road!
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
