Scotty you've gotta give me another ride in the GTR, see how it feels compared to my GTST.
Maybe if your a good little boy :P
when i get my new rotors in i will take ya for a drive, she doesnt stop too good these days :ninja: but that will be soon fixed!!!
Current Spec’s
GTR Front Bar
Vailside Side Skirts
GTR Rear Bumper Fins
Rays Drop Forged Aluminium Rims
Trust Intercooler
Apexi N1 Cat back exhaust
Blitz Pod Filter
Cusco Adjustable Coilovers (Track Spec)
Front Strut Brace
Exedy Heavy Duty Clutch
And lots of stickers!!!!!
Power on these specs was 137.9rwkw
Just added
Re chipped ECU (need to re-Dino for rwkw)
Future mods will be
A boost controller
A Dump pipe
An Aftermarket cat
High flow the standard turbo
Some gages
A Greedy tech Informeter
And some stereo gear
I only want about 180-200 rwkw
Ed say’s with that setup I shouldn’t have a prob getting 220rwkw if I get a bigger fuel pump.
555cc injectors,
Greddy Emanage
Greddy E-01
200kw atw. not much for you 6 cyl boys but itll be very quik for a 200 :(
Its in the shop atm getting kit, sprayed and repaired. god only knows when it will be done as he's takin his sweet goddam time. i met a fella on here who has a white 32 GTR there as well ;)
mind you that prolly wont happen as im going to sell it around my bday and either buy something else or pay out my loan and get a run around and start saving for house and other stuff :P
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
