1978 Datsun Skyline
l24
Shaved and ported head
Twin su
2 1/2 inch exhaust
extractors
trx wheels
$2000 ono
Call brendan
0412 822 312
Hey Brendan,
Can you Pm me with some more details.
Manual or Auto
Any Rust - both panels and underbody
How healthy is the motor
what about teh dash/interior - what condition?
thanks
Edited by NISMO
https://www.sau.com.au/forums/topic/137447-sold/#findComment-2559918
Just thought id add a few things
5 speed manual
Rust in the bottom of the door, and in the sills also had a little in the pillar
interior has a few rips and tears in the back seat other than that not bad for a 78.
Other than that the car goes quite well it goes harder than my mates v6 vt commodore!
The rego is expiringnext month so im keen to off load it!
make me an offer for a classic!
All offers considered
https://www.sau.com.au/forums/topic/137447-sold/#findComment-2567802
