  • Replies 40
would you consider sending wing/s to w.a. postcode 6009?
pm sent
You wouldn't be selling the stock ov would you?
If so please PM me.
Cheers
u mean BOV? if so nah bro i need my bov
  • 2 months later...
hybrid style intercooler piping kit (in blue): $200
factory R33 cooler: $50
2 GTS-t wings (black & silver): silver $90, black $20, both $100
pics
Edited by assyrian4evaa
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
