Howdy all,
i just have a question for those who know.
i have hnr32, a.k.a. r32 with 4wd like GTR.
When i asked a guy about changing front diff oil he said dont need special oil as it uses oil from the engine..
is this right ? so when i change my engine oil do i have to drain the front diff and or fill up the front diff??
i changed engine oil bout 6,000kms ago and looking at changing again in the next few weeks, but wanna know about the front diff...
if anyone knows id appreciate your input :(
thanks
https://www.sau.com.au/forums/topic/137528-oil-change-on-r32-4wd/
they have separate oil.
there are drain and fill plugs on the cover of the diff housing, just below where your engine oil filter sits.
the front diff uses standard diff oil.
r u sure? cz i was changing my rear diff oil at the time, and guy at car shop said i dont need front diff oil, as uses oil from engine... ill have to check into this with some other work shops... dun wanna stuff up my car
have a look under your car dude u will clearly see a filler and drain bolt on the diff and a drain bolt on the sump , the "guy" at the car shop doesn`t know nothing
Engine oil 7.5w30
Front diff 80w90 i think this is just off the top of my head
Edited by GTR32GUS
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
