New Speeding Fines in Qld
That's a worry on the bike, I could see my license vanishing pretty damn quick if there was a cop at the right place at the right time.
Oh well, will just have to do more track days or get an interstate license. NT license still doesn't have demerit points, might get mine back when I go up mid year.
