This is how it goes.. When you say tacho you mean engine revs yes? then you mention speed.
Engine Revs is correct on the power FC compared to the stock tacho meter
SPEEDO can be correct on the indash display and not on the PFC or vice versa OR they could be both wrong.
Get someone in a late model car do some tests with you on speed one check at 40 then 60 then 80 then 100 etc etc
Then you will know which one is correct.
My PFC speedo used to be correct then i got a different ratio diff and now the indash speedo is correct.
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2573605
Yah, I agree with Troy, engine revs would comes from same source, and feed both FC and dash gauge.
The dash speedo though would be from a cable connected to gear box. As evident when heavy breaking and accelerating, there can be huge hysteresis in the needle.
PFC would however take the speed from the hall effect sensors on each wheel for your ABS system. Me think the requirement for the ABS to have a good idea of vehicle speed, would automatically mean its more accurate then the dash speedo.
2c
- Michael
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2574961
I think speedos are all calibrated to overread by a small amount eg 2%. All cars do it.
I would trust the PowerFC especially with the RPM - after all, its the PowerFC that should know it better than a dumb analogue needle because it controls the darn motor!
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2581544
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
