alrighty the time has come to sell my skyline, which is like selling a kidney, i love it i want it but sadly i need something bigger (more doors/ and something with a real boot)
Brad
phone number: 0406316242
this is a one of a kind skyline great car excellent condition all mods done professionally.
silver vinyl stripes on each side gt stripes over bonnet/boot 5spd manual 80,000km series 1.5 mspec drivers side airbag 94 model
rego until 7/07
200rwkw with dyno sheets to prove with the old fmic on
mods include:
HKS spec r intercooler
Radiator Air guide pannel
Gallop Works Garage titainium Exhaust 3.5 inch from dump back catback sounds like 3 rb25's coming out the one pipe tough as just legal.
Blitz Plumb Back BOV still makes a great sound while aiding performance and legal
Apex-i Power FC - tuned by Chiptorque (Rob)
Apex-i AVC-R runs boost at .85bar all day everyday never over also tuned by Chiptorque
Apex-i Power FC Hand Controller
Apexi - Power Intake
Autogague - Tachometer w/ shift light
Starcorp Racing Impul - 18x8.5 fronts slight dish / 18x9.5 rears with massive dish nankang near new tyres
Tenon Pager Alarm Sytem - high frequency shattered glass sensor, shock sensor, tilt sensor and emf sensor
Veilside Rear bar
Bomex Front bar
Autogague smoked face oil temp/water temp/volts in passenger side sbove glove box (looks hot)
Excedy single plate race clutch 10k old
C's Short Shifter - reduces gear change throw 40%
Pioneer p5850 headunit oel display
Major service carried out 5k ago inc.( ngk iriway 7's, timing belt replaced gates racing, all filters, all fluids)
oil/oil filter changed every 5000 km, gearbox oil castrol syntrax 75w90 with nulon gearbox treatment
Electronic Rust Protecton - ozone elite unit
Gtr insrument cluster
Carbon fibre look alike interior inserts
koni shocks and lower kingspring recoils drives like its on rails without the nasty kidney buster effect lowest part of the car is 98mm so its legal
greddy oil catch tank
bosch motorsport in-tank fuel pump
there's more but its not coming to mind atm
ASKING 21,000 o.n.o or will trade for manual stagea dayz edition
i'll get some newer pics including interior up this w/e since these pics both l/h/s and r/h/s vinyls have been redone and the front bar has been replaced and was modded to fit the biger HKS fmic in also now has slimline plates, also the eyelids have gone didn't like them.
Edited by Bullet
https://www.sau.com.au/forums/topic/138240-r33-weapon-fs/
bump
if anyone knows someone witha decent stagea for sale and they are willing to trade lemme know cheers only selling this due to work implications i spend money on my car my work gives me money haha can't do the one i want without the other :)
https://www.sau.com.au/forums/topic/138240-r33-weapon-fs/#findComment-2631394
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
