Hey everyone.. Ive recently purchased a 1997 series 2 r33 GTS... And when i bought it i was in the understanding that it had stock suspension.. but after close inspection of the car it has NISMO motorsports suspsension on it.. Is this stock with all skylines? Or just the GTS's? And another thing.. I was sure that ALL skylines came out with HICAS.. But my nissan fast results tell me i have IRS? Any comments would be great thankyou..
https://www.sau.com.au/forums/topic/138262-gts-suspension/
nismo suspension isnt standard.
irs stands for independent rear suspension - what this means that each of the rear wheels is independently sprung, as opposed to a rear axled car.
hicas refers the the four wheel steer movement of the rear wheels, the simplest way to check if you have hicas is to turn your car keys into the acc position and check your dash for a hicas light.
you can even feel the rear end turn its wheels when you go around a round-about, it tends to feel slightly drifty. most people lock the hicas as it tends to make the rear end unpredictable for track use.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2575005
nice find if its come with nismo tuned suspension
if ur willing to jack the rear up u will see (if uve got hicas) a big solenoid thingo in front of the diff (ie blocking the diff from ur view) and coming from that are some arms with boots on the ends of them (black rubber things to stop dust and dirt getting in) that go towards the wheels.
if u see that then uve got hicas - it controls the rear toe arms to essentially turn the rear wheels in accordance with the speed ur going to make the turn 'easier'
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2575141
Hey thanks guys..
Obviously nissan fast was wrong because i have hicas :P
Found it in the dash AND there was a fuse for the hicas in the fusebox...
Maybe the last owners put the nismo suspension on it? Im the first owner in the country so... the whole car is a foot off the air as well... Which made me think that it was stock
4X4 spec
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2577756
Well it turns out i was wrong.
There is A. No hicas light. And B. nothing that remotely looked like hicas under my car :S
I actually have no idea. Ill post some pictures of my diff and suspension and let you guys be the judge.
Just got back from looking over the car.. In my fuse box in the boot there is a fuse for hicas but im not sure if the box they made to cover the box is a standard for all skylines or just for GTS's... And i also found a weird box with heaps of wires comming out of it lol. Pics attached.
Edited by OBNXSH
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581242
this is what a hicas lock bar looks like
in its place should be a big solenoid thingo
the rubber boots are connected to the toe arms that turn the rear wheels
(PS this is the first decent pic i found, i'll try and find more)
which is from this car by the way which is MAD: http://www.cardomain.com/ride/447636
Edited by usherly
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581417
thought you said you had a hicas ecu and a light on the dash?
from the photos no hicas there... congratulations you just saved yourself $150.
I overlooked it... It said ABS lol dont ask me how i got HICAS from abs but i just did... The one thing that puzzles me is on my fusebox in the boot it says HICAS as the 2nd fuse from the bottom... Maybe its just the universal cover they make for all fusbox's on r33's. I suppose not having it is a good thing.. Most people dont like it? Also what did i save $150 for. lol sorry.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581449
no idea how u mixed them up.
like i said in my pm to you, most skylines would probably just share parts between for all the various options in skylines.
well no most people don't like hicas, its ok for street use, makes turning a breeze, but for track work it makes the rear end unsteady and unpredictable... you saved $150 for a hicas lock bar (elminates hicas on hicas enabled skylines) - that silver thing in usherly's post.
https://www.sau.com.au/forums/topic/138262-gts-suspension/#findComment-2581468
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
