Guys I'd love to hear your thoughts on what may cause the problem I'm having with a stereo. It's on our Mazda, not the Nissan, but SAU is where I've always found guys willing to lend a hand.
When we bought the car a year ago, RL and RR did not work. We didn't care, it is a spare car. When FR dropped out (as in, the output volume dropped to negligible, but audible) we assumed the speakers were slowly dying (its a 1993 car).
I removed FR and suddenly the rears were working again!? At the same time, FL was MUCH louder the the rears combined.
I thought the lack of FR may be causing an overvoltage to FL so I removed that one too. Now the RL is louder than RR?
Anyway, I'm stuffed to work it out. If it matters, the fronts are splits and I only removed the bass driver from the door. I was hoping someone here could shed some light on the cause before I ask someone to come out to my place. I'd rather avoid rewiring the whole car if i can help it.
Thanks guys, any assistance would be appreciated. Cheers
Mark
Did the stock HU use a common ground for fronts and another for rears? Or are you simply reusing all the original wiring?
Sounds like you might be using the negative of one speaker on another speaker or something like that?
Hi Randy, thanks for the post. The wiring was ambiguous so I had to test both ways (both wires had a trace colour). To be honest, I couldn't tell the difference either way. I guess I'll go back and swap them over and check again.
Now that both fronts are gone, RL is still much louder than RR and both lack the bass you'd expect from a 6x9 - they sound more lie 4's :O
Chris here's those pics. Thanks for taking a look.
For what it's worth, the new speakers are 45W RMS. Could I be asking too much of the headunit? I wouldn't think so, but thought it worth mentioning as it's an old car.
Cheers guys
i know its probably not this but if it was you would look a bit silly. its not something simple like the balance knob from left to right is it? cant see from the picture but some stock radios have that little knob around the volume knob that balances it, or sometimes is the bass control.
Cheers Jason but yeah I've played around with the fade/balance/bass/treble. That was how I've been diagnosing the differing output. Hey there are no things that are silly, always helps to start from the start rather than assume :rolleyes:
I haven't touched the splits, although I have removed the bass drivers from the door. The tweeters still have some poor quality noise (won't call it sound :laugh:) coming out of them.
Could that be related?
Hey thanks Chris. It is a 1993 Mazda 626. I'll take a pic this morning. Its a Phillips two single DIN setup. One has CD only other has cassette and radio.
I'll come back with pics.
ok if its a sedan check the rear wiring ont he speakers. if you shove a lot of stuff in the boot there is a good chance that you have knocekd the terminals off the speaker and they are shorting.
this will do a few strange things to the radio- one of which you have already described.
Now that both fronts are gone, RL is still much louder than RR and both lack the bass you'd expect from a 6x9 - they sound more lie 4's :)
Cheers guys
one thing to also look at (now that I have mroe info) is the crossover network. depending on how lound you have it most amplifiers will go into protection at 3/4 volume so that may be a thing as well.
first thing I would do would be to eliminate te crossover on the offending side and see. as for power - nope. you will kill them with too little power but that isn't your current problem.
Maybe for fun, use the RL (loudest) wiring from the HU, and just hold them to the wiring for each other speaker and compare? If all the speakers are just as loud, then it'd be a HU problem I'd assume.
If they still act up, then yeah.. you could have a few shorting somewhere, or a dodgy crossover.
Hmm.. still.. the whole thing screams wiring... like common ground. You have the stock speakers, right? My lady's Honda was crazy like that too.
It was almost like the commonly-grounded speakers were doubling the resistance back to the HU. (halving the ohm value) and therefore upping the HU's wattage output. I doubt this is the actual case, because 8ohm stuff is generally reserved for HiFi stuff, and cars use 4ohm and sometimes 2ohm for subs.
Anyway, definately troubleshoot it down. Unplug all from HU. Grab the loudest output pair from the HU, then test them to each speaker. Shouldn't need to power the HU off for this test.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
