what are the spring rates do u know? These are damper adjustable too?
The site quotes this "This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm)." There are 15 levels of adjustment.
I'm fairly sure spring rate is around 10kg. I have shock-dyno results for these at work, too.
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2583882
good price.... how firm are they do you fell evry bump on the road??? why u selling up? also will they fit a r34 sedan???? sorry for all questions just bought my car not sure what fits!
Edited by rgr34
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2630433
They are reasonably firm, yes, and that's more or less why I'm selling them (ie. the roads around my suburb are equivalent to a minefield). If you can live with a slightly ride, though, you would really have to look very hard to find better enigneered and better handling items.
As far as fitting a sedan, I cannot see why not, but probably best to use the search function in the suspension forum. Can anyone shed any light on the subject?
Edited by oblivo
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2630626
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
