Ive done it with no adverse effects that i can tell, apart from it looking crap.
But there is barely 1mm of clearance between the rims and brakes at the moment. Just means i dont use the brakes as much :), which makes for less thermal expansion.
I would say dont do it if you can avoid it, im assuming its to fit some rims in the wrong offset. Ive actually bought another set of front calipers and im waiting for some nice rims, so i can put "untampered" calipers back on. i reckon the cops probably wouldnt like it either.
cheers
Evil
But there is barely 1mm of clearance between the rims and brakes at the moment. Just means i dont use the brakes as much :P, which makes for less thermal expansion.
cheers
Evil
thanks dude its actually for an r31 ill look into it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
