For sale: 1992 R32 GTS4 Skyline
Asking Price: $13,000 o.n.o
Killometer's: 11X,000km
Manual or Automatic transmission: Manual
Engine Type: RB20DET
Modifications: FMIC Intercooler, 3.5" Full Exhaust, GReddy Turbo Timer, 500hp Walhbro Fuel Pump, Malpassi Fuel Regulator, HKS BOV, K&N Pod Filter
Complianced: Yes
Registration: 21/07/07
Crash History: No Accident History - Inspection Welcome
Other Comment's: The time i have owned the car, all work has been done by Autosport
Interested in swapping, trading for same or lesser valued cars with extra money my way...
Pictures: http://www.nissansilvia.com/forums/index.p...12&CID=1390
Contact via PM
https://www.sau.com.au/forums/topic/138990-fs-r32-gts4-skyline/
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
