Man I'm stupid, finally figured it out. All the pics I keep seeing of the 350gt-8 are the 2001/2002 models. Mine is a 2003 and has had a few changes. I found this on the nissan global site:
Skyline Sedan Undergoes Minor Model Change
Among the refinements made to the Skyline Sedan this time, the 2WD models now have higher spring rates, shock absorbers with approximately 30% greater damping force and larger-diameter stabilizer bars for better control of body motions, compared with the previous models, and thereby deliver a tauter driving feel. In addition, braking performance has been enhanced by adopting a braking system incorporating high-performance sport brake pads with an increased friction coefficient and highly rigid brake rotors with an outstanding heat radiation characteristic.
The exterior design projects a sharper impression than before as a result of applying a smoky chrome finish to the grille and headlamp inner panels and changing the sill color from gray to black. At the rear, the car badge and Skyline emblem have been repositioned to give the rear-end a wider look.
On the inside, the audio and heater control switches have been embellished with a chrome accent for a higher quality image, and the 250GT and 250GT FOUR models are provided with rear-seat air-conditioner vents for enhanced occupant comfort.
The grade selection has also been reorganized as part of this minor model change.
<Major specification and equipment refinements>
Exterior
Repositioning of the rear car badge and Skyline emblem
Refinement of the design of the radiator grille, headlamp inner panels and sills
Addition of Sparkling Silver Metallic and Rose Red Pearl as new body colors for a choice of six attractive colors altogether
Interior
Refinement of the control switch design
Adoption of sun visor extensions
Addition of a light to the front-seat vanity mirrors
Adoption of a double-pivot rear-view mirror
Expanded application of rear-seat air-conditioner vents to the 250GT and 250GT FOUR models
Mechanisms
Refinement of the suspension and braking system
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2591299
yeah i saw one of these on the road a while ago, and it threw me. didnt know it was a skyline till i saw the badge. looks more like the new maxima or something.
what engines do these have? turbo? i know i could google it, but meh.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2604721
ok, i cracked and googled, lol.
3.5L DOHC V6 NA. meh. i dont really like it. very family/maxima. how can they call this a skyline????
VQ35DE (NEO) type V 6 cylinder DOHC with an X toroid CVT 8 speed transmission.
It's more than worthy of the skyline name and is totally different to a maxima.
I parked mine next to a maxima the other day and they look totally different.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606849
id get the coupe - but its similar to the 350z i reckon.....bah just slap on a turbo when modding it - works well either way....
Edit - ok maybe interior is not that much like the 350z - i dunno...gives me the impression that one of them was trying to copy the other....
Edited by emsta2003
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606996
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
