so if I'm reading correctly too much air ramed in is not doing you any good.
I setup a box over the pod and AFM and took away the stock intake. I used a 3" pipe from the grill which comes in under the pod - using the stock IC hole..I havn't noticed any issues... I would assume this setup is basically the same as stock with more air and a more direct flow into the CAI area however the differnece is that its not in direct airflow at the bar...yet I would assume the 3" pipe would allow a lot of air to get in...maybe its enough of a baffle to avoid the issues being discovered.
Its not totally sealed...it has gaps on the sides..I never worried as I assumed so much air was getting in there it would keep away the hot engine air...after all that was the aim of the box...I wont bother to seal it up perfectly then
Maybe you don't need such a good flowing filter under such circumstances...as you have so much air its not really a flow issue. I have been using a UniFilter which has less flow than the pod mentioned but filters much better...just another thing to consider IMO...
Id say, its not so much that air being rammed into a inlet system is bad, its just, the engine as a complete unit inside the car, was tuned on a dyno with a certain pressure in front of the turbo mouth, at a certain altitude, with certain fuel etc… so EVER changing those parameters is going funk with things; someone here actually measured the difference in AFM outputs with the engine off, rolling down the road! - gonads of tungsten. You’d think if you TUNED the car with that extra pressure it would be fine. Hahah how bout a MAP sensor near the AFM to trim output as pressure goes up? Or directly trim the AFM output voltage as wheel speed sensor output rises lol. Wait, that might not be so hard, don’t stock ECU’s register relative pressure / altitude every time you start your car to compensate? Hrmmm.
Make me wonder how other groups of people have gotten around the issue. Ninja 500’s with those ram air snorkels at the front, GTHO’s with “shakers”. Hrm maybe carbs aren’t effected soo much, as fuel delivery is based on air speed over a venturi; with the engine only swallowing a certain amount of air. Wonder if a jet engine gets this compressor reversion… jk
Troy a slightly unsealed box would probably suit best, biggest disadvantage being some warm air creep into it, when the vehicles still, hrmm.
Wooah, sorry, mental gibberish, too much strong coffee!
- Michael
Well Said GeeTR
Maybe just a aluminium cover for the front bar with holes drilled in it to restrict the air flow so it does not ram air into the AFM.
That might be the go...
I'd be more worried about the fundamentals...
filtering of air with the filter hanging directly in the duct?
how well do pod filters really work?
i personally wouldn't want to risk my motor by ingesting more particles that strictly necessary... plus by 'boxing' up the duct, how is it any more effective than boxing up the filter in the engine bay?
plus, if you're sitting in traffic, the 'hot' engine air would be so quickly purged with a ducted box in the engine bay anyway.
you might make 2kw more.
Well Said GeeTR
Maybe just a aluminum cover for the front bar with holes drilled in it to restrict the air flow so it does not ram air into the AFM.
Thanks Guilt-Toy.
Plate with holes yah, but then at low vehicles speeds, you’ve lost a lot of the benefit hrmm *ponders*
Ronin - true, having more air flow around the filter would theoretically mean its going to see more dirty air… or does it.
A engine bay exposed filter would have a large amount of air around it as well i woulda thought. Through the front bars largest opening, between headlights, through the radiator, off the firewall, then prolly straight down underneath the car… “Would” a boxed, and ducted pod see more air flow then a pod exposed in the engine bay at 100km/h? Dunno
“Boxing up the Duct” > I think there’s a little confusion as well. I’m talking about boxing the filters in a GTR engine bay, so from the passenger strut tower all the way forward to where the charcoal canister is (was)
Put a 4” hole ( where the battery tray is on the other side.. but of course, we are talking the passenger side here) that would be big enough to force most of the air through the stock bar vent, into that boxed area.
Guilt-Toy, i belive is moving the actual filter to the front bar.
I’m thinking I can remove some of this heat soak, you mention, by having the box sealed 100% and high density foaming every surface inside. Moot maybe, but I still wonder, when I hold a 60 degree coffee in a cup made from 3-4mm of polystyrene.
Please don’t misjudge my enthusiasm, I think its documented, and fairly common sense how to get around the problem, tojust make it simply "work" I’m just tongue in cheek interested in how one would make the perfect setup if one had time :D
- M
Edited by GeeTR
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
