Hey guys i just want to find out from you guys who have the same car (and only you please) with the standard pump, how long it primes for in the morning or after many hours of not running. If you don't start the engine when the ignition switch is turned to 'ON' how long do you hear the pump prime for? Is it very loud? And lastly do you ever hear the same prime noise for a very short time (1 second) during prolonged idling? ... memory this too is only after the first start in the morning or after many hours as previously mentioned.
Many thanks,
Deren
Yeah cheers for that mate. How about the prime during idle?
BTW just realised your after a nissan boot badge, i dont think i will be using mine anymore so its yours if you take me off your bad trades lol!
Edited by Godzilla32
Many thanks,
Deren
The sound came on due to lack of lubrication in the fuel pump, you can either put Redline SI-1 in your petrol tank or buy some ashless motorbike 2T, added 50-100ml and it will do the trick.
Edited by Trex101
Not on the GTR. I just cleaned the TB on my Mazda's KG 2.5L V6 and it ran like crap quite some time... next time I wont be lazy and I'll take the TB off rather than just spray all that carby cleaner down its neck :)
Is it a tough job? I'm sorry about dragging things off-topic, but my plan is to clean the IAC, clean the TB and then if it is still high I'll adjust the trim pot on the ECU. I'm pretty sure it had an aftermarket ECU removed prior to export, so the problem could be there...?
Dont clean the throttle bodies, It wont make it any lower, only higher, the more you clean from around the butterflies the more air gets thru when they are supposed to be closed - Hence high idle. Prolly the idle control valve getting stuck. Good place to start anyhow :laugh:
Dont clean the throttle bodies, It wont make it any lower, only higher, the more you clean from around the butterflies the more air gets thru when they are supposed to be closed - Hence high idle. Prolly the idle control valve getting stuck. Good place to start anyhow :)
Very good point dude! Cheers
Thanks guys. Sounds like i have no problem then :)
Its not the attesa pump. There would be no need for it to operate at idle. Only works when you are locking up the clutch packs in the transfer case to provide front torque.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
