yeh im going either the gtss or gt2860 both make good power,and good response ive heard
Im thinkin of doin the same there Gunner i was sweatin on the GT_RS's but from what ive heard the 2871's might be the same laggy but good power from 4grand onwards
Hi mate i have them on my gtr and it made 510hp at the wheels on 22psi and 345kw on 17psi at the wheels they come on boost around 3000rpm and make strong power all the way to 8000rpm they work great with the right set up i have all the dyno sheets if you need any more info drop me a line thanks Jason
what else have you got in your motor?? stand 2.6L? cams?? see 3000rpm is not too bad...care to share a bit more?? cheers
thanx guys, just i thought this thread was dead
coming on boost is what? = 1psi, 20psi?
Loaded up on a dyno on 4th or on the street?
There is no way your going to see anything decent before 4500rpm on a stock capacity RB26.
They are 400hp turbos, not 300hp GT-SS or that ballpark turbo
Again, is that loaded up in 4th on a dyno?
Or are you seeing this sorta thing with a roll-on in 3rd.
Its hard to gauge and compare the two as they are totally different to each other.
Not saying your results are false or whatever, just trying to get an accurate picture
frankxinyu - whats your use for the car?
as topic states, is anyone using twin Garrett GT2871s on their GTRs? if so, how laggy are they? and what kind of power are they putting out?
cheers guys
frankxinyu the garret Gt2871 are basically the HKS GTRS turbo and are quiet common on the rb26 but they have had mixed results. They do make more power than the 707160-5 gt2860r but not by much and the turbo responce loss i believe doesnt out power gain. The best results gained fromt the HKS GTRS/GT2871 have been on stoked rb27/28 or rb30. You find it hard to beat the garret Gt2860R 707160-5 or HKS 2530 for alround twin low mount turbos.
Pete
This is the -5s at only 17psi with basic tune as the injectors are 100% duty so by the time we fit bigger injectors and run 24PSI with a full tune i really cant see the point in looking past these turbos for a dual use car and the price it right. RB26 std stroke and head,260Poncams and single throttle kit on stock intake so the engines not wild,shows how good the turbos are.
Boost controller is now sorted so boost is now earlyer and flatter.
i do wanna maintain the street drivability, but it will see some track days.
by talking to another owner who is running twin GTRS on his stock RB26, these turbos are way too laggy on the street....i think i am going to stick to GT2860s-5
thats awesome figure....
the thing is these 2860s are so cheap nowadays.. they are cheaper than the GTSS ones, yet still make more power.....
To a large degree the jump from a 60mm to a 71mm compressor is going to affect the boost threshold because you have essentially the same sized turbine and housing with the same exhaust gas velocity trying to spin them up .
Lots of people ask me what is the next step up from the bigger trim 60mm compressors ie 2530's 63T or the high tip height 60mm 62 trim from the GT28RS/2860RS . So next up in Garretts GT range is the 71mm wheels (GT 35 comp series) which my list shows three sizes .
1) 71mm 48T , 49.25 inducer diameter , 4.75 mm tip height .
2) 71mm 52T , 51.20 inducer diametre , 5.00 mm tip height .
3) 71mm 56T , 53.10 inducer diametre , 5.00 mm tip height .
The larger trim and exducer tip height wheels have greater pumping capacity but it comes at a price , moving more air for the same wheel rpm means they need extra power to drive them . If the extra shaft power is not available then we need more engine revs giving more exhaust gas velocity to power the turbine/s . Basically the big trim/tip height wheels with the same turbine force a slip loss effect of the exhaust gasses round the turbine blades . Its a lose lose lose situation because boost threshold goes up , exhaust restriction goes up , detonation threshold comes down - backpressure if you like forces exhaust gas reversal back into the chambers in the overlap phase so charge dilution and preheating as well as pumping losses . All biggies .
Note in (1) above that the 48 trim 71mm wheel has obviously a smaller inducer diametre size AND lower exducer tip height . This is the next incremental step up from the 60mm GT compressors and will generate a bit more airflow (maybe 3-4 lbs) but have the least negative side affects of the three 71mm compressors . I don't think I'd go past this stage if at all on a standard capacity RB26 because its already starting to turn laggy and getting a bit hot and restrictive on the turbine side if really pushed . Probably more to be had from porting and cams with less trade off . 2860's and 2530's seem to be the sweet spot and after that really need larger turbines to compliment the larger compressors . This then really pushes the boost threshold up and increased capacity is the only way to help bring it back down .
Cheers A .
Edited by discopotato03
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
