Hi Fellas,
I was wondering if anyone's had experience using oil filters other then Nissan genuine ones on their RB25DET NEO engines. Can filters used on Cefiro's, Primera's or other Nissan cars fit on the engine?
Edited by sarnil
https://www.sau.com.au/forums/topic/139364-rb25det-neo-oil-filters/
Just a note, after Nov 1998, R34's use a smaller filter to the standard z145a older R34's use. Both still fit though, but the smaller filter apparently has a different micron rating.
I have yet to find an aftermarket manufacturer locally for the later model R34's. So you're better off getting them from Nissan, they're cheap anyway.
Thanks Howie,
The last filter I used was the smaller version, but I had sent from Japan. It wasn't Nissan Genuine, but of the PITWORK brand (which I think is another Nissan brand).
Mine is a 1998 model, probably part of the earliest batches of R34 models.
Thanks Howie,
Send me your Vin number mate, i'll tell you what it should be.
Edit : Also if you use the larger filter obviously you'll need close to or more than 5L of motor oil.
Edited by Howie
All Skylines up to 11/98 use the Ryco oil filter Z145A or equivalent.
Skylines from 11/98 onwards use a Ryco Z442 or equivalent.
Hope this helps.
http://www.rycofilters.com.au/catalogue/ap...n/model/Skyline
Hi Howie,
The VIN number is RB25106146
Edit: the above is actually the engine number. The VIN # starts with ER34*****
Edited by sarnil
hi guys,
sorry to hijack your thread sarnil, but i've got a 1993 R33 GTST series 1 and when i went to nissan to purchase an oil filter he gave me the oil filter part number 15208-53J00 and he's very certain that it would fit on mine.. is he right ?
cheers
seconded. or a Cooper filter, they are good quality too.
confirmed. Tests have shown Ryco to be crap under the generic brands...and coopers performed really good. The OEM Nissan seems to be good also and plenty of good reviews detailing low pressure drop and good filtering. Considering I got some for $9.50 each you can't go too wrong.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
