I believe there were some they didn't come with hicas as there is a powersteer pump available without hicas.
Most likely the n/a base model.
I'm probably wrong though as I don't know for sure.. Just something I vaguely remember.
I found heaps of R33's that didn't have HICAS, & they were factory original.
When I bought mine it was the only one I'd found with the system on it & these were only just complied cars we're talking about here too. The setup is actually a bit different & lacks the adjustments for toe that the HICAS type rear end has.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2707798
  • Replies 97
- re-instate abs control function. (doesent have abs.. IDIOT) supply report stating operation ok
Hmm, I thought this one interesting, but I suppose it part and parcel with inspector inconsistencies.
When my car went through, I had the ABS fault light ON (I've turned it off due to common problems with it) in orange on the dash and no comment was made about it. ABS shouldn't matter if you can pass the breaking test.
Best of luck
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2708498
Best of luck
i have passed the breaking test.
thanks helso for the offer, when i can find the hicas i may take you up on that. :D
dam, they system is setup to focus more on the technicality than the practicality!
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2709391
Yeah bud, if there's a lock bar in place, we could do a swap. The only problem I forsee is that it requires a wheel alignment to be done after the swap, so if you wanted the bar back, you'd have to get two alignments done. For a time frame, I'd go with Nozila's estimate, but, now that I've done one, I think I could shave a half an hour to an hour off of it
Edited by heslo
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710729
thats true, once you 'crack' the bolts so to speak, its alot easier to unbolt and re-bolt. i didnt have that luxury as i stated, i was first time the bolts were unbolted. but since you have (i presume) a lock bar then your bolts would be easy as to undo. pain in the back side none the less. wheel alignment is highly advised.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710855
maybe it would be easier to just borrow one thats already off, wanna lend me yours nozila?
i have to replace my battery in my boot with a dry cell batters i have been quoted $480 for one.
wat the hell this is bullshit, F@#K this government. seriously!
Edited by DriftR_33
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2711010
Yeah, it's screwed up but what can we do? If you don't want to swap with mine and get a replacement that you can use, I'm still more than willing to lend a hand.
thanks mate for willing to help me... :)
my mate found me a r33 hicas today and have installed it. cost me nothing HAHA :D:)
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722137
. We need cops that stop crime instead of discriminantely fleecing certain members of the public & making them out to be the crims instead.
true ^^
1 of the reasons why i sold my old 33gtr years ago...they pulled me over and gave me a fine for changing lane @ a roundabout (glenelg) near the revolving restaurant. Another time they pulled me over to search for my 2 bov, but being stupid noobs, they couldnt find them, bov are under the engine bay in GTRs.
just anything they could find, they'll make that extra effort to fine/defect u
while the real bad guys are still out there doing the real damage
so bl jase, just a bad day out @ kfc :D
Edited by andz69
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722158
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
