I believe there were some they didn't come with hicas as there is a powersteer pump available without hicas.
Most likely the n/a base model.
I'm probably wrong though as I don't know for sure.. Just something I vaguely remember.
I found heaps of R33's that didn't have HICAS, & they were factory original.
When I bought mine it was the only one I'd found with the system on it & these were only just complied cars we're talking about here too. The setup is actually a bit different & lacks the adjustments for toe that the HICAS type rear end has.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2707798
  • Replies 97
- re-instate abs control function. (doesent have abs.. IDIOT) supply report stating operation ok
Hmm, I thought this one interesting, but I suppose it part and parcel with inspector inconsistencies.
When my car went through, I had the ABS fault light ON (I've turned it off due to common problems with it) in orange on the dash and no comment was made about it. ABS shouldn't matter if you can pass the breaking test.
Best of luck
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2708498
Best of luck
i have passed the breaking test.
thanks helso for the offer, when i can find the hicas i may take you up on that. :D
dam, they system is setup to focus more on the technicality than the practicality!
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2709391
Yeah bud, if there's a lock bar in place, we could do a swap. The only problem I forsee is that it requires a wheel alignment to be done after the swap, so if you wanted the bar back, you'd have to get two alignments done. For a time frame, I'd go with Nozila's estimate, but, now that I've done one, I think I could shave a half an hour to an hour off of it
Edited by heslo
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710729
thats true, once you 'crack' the bolts so to speak, its alot easier to unbolt and re-bolt. i didnt have that luxury as i stated, i was first time the bolts were unbolted. but since you have (i presume) a lock bar then your bolts would be easy as to undo. pain in the back side none the less. wheel alignment is highly advised.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710855
maybe it would be easier to just borrow one thats already off, wanna lend me yours nozila?
i have to replace my battery in my boot with a dry cell batters i have been quoted $480 for one.
wat the hell this is bullshit, F@#K this government. seriously!
Edited by DriftR_33
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2711010
Yeah, it's screwed up but what can we do? If you don't want to swap with mine and get a replacement that you can use, I'm still more than willing to lend a hand.
thanks mate for willing to help me... :)
my mate found me a r33 hicas today and have installed it. cost me nothing HAHA :D:)
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722137
. We need cops that stop crime instead of discriminantely fleecing certain members of the public & making them out to be the crims instead.
true ^^
1 of the reasons why i sold my old 33gtr years ago...they pulled me over and gave me a fine for changing lane @ a roundabout (glenelg) near the revolving restaurant. Another time they pulled me over to search for my 2 bov, but being stupid noobs, they couldnt find them, bov are under the engine bay in GTRs.
just anything they could find, they'll make that extra effort to fine/defect u
while the real bad guys are still out there doing the real damage
so bl jase, just a bad day out @ kfc :D
Edited by andz69
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722158
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
