Urgent: Whats This Unit? Whats The Hose For? Leftover From Fmic Installation.
Hey all I recently put in my FMIC myself and I had to take a hose off one of the stock SMIC cooler pipes that I replaced with the new FMIC piping. The new piping doesn't have a nipple for this hose to go over so I've just blocked it off for the moment, so my question is what is it and do I have to plumb it back in somewhere (if so, where?) or can I just leave it blocked off? Or I leave it open to air?
And whats that unit which the hose is coming from?
Thanks all!
Andy
Edited by OnGsTa
Hey Andy,
It’s the qoibble relief line, and plays a key role in relieveing pressure from the qoibble pump behind the dash. Be careful what you plug it up with, removing the dash is a real nuisance.
Hope this helps
M
Thanks for the quick reply M. It was plugged into the cold(?) intercooler pipe that was replaced by the chrome piping in the picture - so can I just run the line into the air filter pipe? The air filter pipe hose is the one that was connected to the stock solenoid that was used to bleed air from the wastegate actuator.
P.S - what does the quoibble do?
qoibble (qoi- bble)
1 - deceptive, misleading, or false nature; erroneousness, created on a Friday to poke fun.
Sorry man, I was just joking, i have no f'n clue what that is ;)
Try downloading work shop manual for the car. Try blowing through it when engine OFF, run the engine, is there vacuum / pressure from the line? From the location you took it from... the pipe would see mostly high pressure, not vacuum.. *thinks*
Good luck
Cheers
- M
mad082: I belive that unit is indeed linked to power steering as when I move the steering that loose hose starts to SUCK air. Is it the power steering unit?
Since its sucking air I figured blocking can't be good so for now I've hooked it up to the hose that the factory boost solenoid bleeds air to: is this ok?
P.S - the stock wastegate is now controlled via profecB ebc.
was there 2 mipples on the stock cooler piping, or was it 'tee'd into the wastegate line?
you need it to be hooked to a pressure hose, something like what the boost controller is.
Ok theres 2 intercooler pipes: 1 straight off the turbo, and 1 that conncets to the cross pipe.
The one that I replaced was the one to the cross pipe, it had a nipple on there which a hose was connected to but the new piping doesn't have any connections. Thats the hose in the picture in the first post where
The turbo side intercooler pipe also has a nipple which now has a hose going to my boost solenoid, then solenoid to the actuator. Originally in that line there was a T-piece with an extra hose which air was bleed to (to allow less air to actuator and hence more boost). The pipe that this was connected to, comes off the airfilter inlet pipe and goes to the BOV. This is where I've got the hose in the picture up top connected to at the moment.
i'm getting my self all mixed up.
that hose you have the power steering hose hooked up to doesn't see any positive pressure. hook it up to the same hose as you have the boost solenoid hooked up to.
Edited by mad082
Cheers will do, thats probably why the car felt abit laggier.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
