Paul Efantis from Maryland, USA just ran a nasty time qualifying in TX:
2950#, stock IRS rear, TH350 trans, no nitrous...
60' 1.418
330' 3.68
1/8 5.53
MPH 133.50
1000 7.12
1/4 8.467 @ 167.28 MPH
This was on BF Goodrich DRAG RADIALS!
Paul also can be seen street-driving the car in his home town. :uh-huh:
https://www.sau.com.au/forums/topic/13953-supra-usa-drag-et-record/
Originally posted by ice180
looks awesome can't wait to see the vids.  Friend is currently rebuilding his with big single turbo previously had twin TD06's should be a weapon...  Starting to get a bit cheaper here.
Cool! Need more fast MKIV Supras from down there! :uh-huh:
Originally posted by hippy
2 speed auto?? can someone explain to me how that works??  seems most drag racers are slack like me and have an auto  :spank:
GM Powerglide. Been in most 1960's US cars and light trucks. Lots of drag racers use them in highly modified form. Usually found in rail dragsters...
Dragsters use autos cause
A, autos change gears a hell of alot faster
B, autos are alot more constant, and constancy is the key to bracket racing
C, autos put less strain on the drive train, unlike a manual the power is built up through the drive train when they car is stalled up, no sudden surge of power from a clutch drop.
and yes, 2 speed autos are popular in drag racing. The glide is a very very strong gearbox in a built up form. Also pretty cheap.
are you talking about Nigel's Supra?
if so i asked him the other day what turbo he was going for and he said that he was probably gonna stick with the twins
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
