  • Replies 130
Definately count me in! Im a member of NS.com but Nightcrawler invited me to join. I wanna see what I get on a calibrated dyno. Got 152rwkw @ Tilbrooks, 153 @ REVS. Havent done any significant mods since... Its an S14 btw.. =)
Oh btw, can I do one run with the AFR probe (to verify my SAFC fuel maps are still good) and another later on with boost graph logging? I reckon my Autometer Boost gauge isnt very accurate..
Thanks Martin!
Originally posted by Nozila
and why is it sad. you are starting to annoy me.
Since you make constant references to others having too much money in your posts, I have done the right thing and contacted Morpowa to see if they could do you a 'concession' type deal. They are keen to help.
Its sad, primarily because, a) you are supposed to be friends with your fellow SA forum members, and B) you think I give a toss. If I annoy you I am truly sorry!
My apologies to all, as I will no longer be able to attend the dyno day :( A family hospitalisation is occurring at the same time.
I hope the day is a good one & everyone enjoys themselves :) I was looking forward to the BBQ too!
See you all on the drag day. I won't be missing that one!
Cheers,
Matt
i think i have to pull out too ... my car is falling apart right now ... having problems installing stuff and its too messy :( .. besides the boost controller i was going to put in hasn't come yet .. :P .. oh well i think there might be a rpm dyno day coming up soon ... might go to that one ..
