steering bushes / rack are apperently fine, 2 mechanics have looked at it , i wouldnt know a thing about it myself
i can't see any evidence of acidents and i'm sure suspension places or mechancis would have pointed it out as the easy way out of a question by a customer (should be easy with the car on a hoist which they have had it many times)
i went to swap my friends r32gtst 4's wheels to brothers r32 gtst just yesterday. turns out that suspension components must vary greatly between these two cars, as there was insane scrubbing with 18's on the gtst, so we werent able to test the car with new tyres and wheels!!!
i might look into the discs being out of balance. will a simple machine of the discs pick up on this?
The commodores are well known for their tailshaft center bearing crapping its self, especially the VN's. :)
They will send a vibe up through the steering wheel on accel and when it gets worse on cruise. I had mine done on the VS 5ltr twice, they don't last too long.
My tail shaft uni joint is shot to hell in my commodore. It shakes the steering wheel to the shit house.
Change the uni joint. Problem gone.
Regarding the shake at 110km/h. I had that with my old gearbox in fifth gear. Drop it back to fourth and there was no vibration. The vibration you could feel up through the seat and slightly on the floor pan. It would slightly vibe the revision mirror where it was difficult to focus in on cars behind.
New gearbox after it stripped third gear and no more vibe.
So try that.. Get it vibrating.. Drop it back a gear and keep cruising. :)
before you spend another cent swap all 4 wheels with another set even if you have to beg borrow steal them just to test the car.
wheels are the largest ammount of rotating mass and will be the easiest/cheapest thing to fix/diagnose.
cheers :(
you would thing flat spotted tyres would be picked up in a simple balance?
A flat spot will just show that one side is slightly heavier, add weight to the other side. Problem still happens that the tyre goes round round round FLAT round round round FLAT.
Each time it hits a flat, it "hops"/"shakes"
Major badness!
the tyres on the front are brand new, my brother doesnt lock up the brakes
before i could suggest an on car wheel balance he has got the discs machined and said that its fixed 90% of the problem. yay. so its better then its ever been but im guessing there is still something there
thanks for your help so far, i wonder if the rest can be fixed too
hi there.. where did he get the disc machined, how much did it cost and how long did it take?
did he have to take the disc rotors out himself or just drive to the disc machiniing place and they'll do it all.
thanks
dont know any of it
but its hell cheap and they'll do it all for you and it doesnt take long
even kmart tyre and auto does that stuff! its like $20-$30 a disc, all labour included
but it'd be best to do an on car wheel balance, it would compensate for anything being out of sync. -unless you are getting vibrations when braking (warped discs, fixed by machining / new discs)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
