  • Replies 221
Posted Images
Alien - R34 & Evo 9
Abo Bob - R34
Security - R33 mayb
DIF - R32
Silver Gtst - R32
Smoky - R33
blk180 - 180sx maybe
Liz - R33 or 180sx or whatever she has now
FREAKU - R34
JAS-25T - R33 maybe
NSA11N - R33
RT33 - R33
R33GTRVSPEC - R33
Amy33 - R33
mr 32 - R32
Miss Turbo - R33
Mintie - R33
bored33 - R33
MR 33 - R33 + mates maybe
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
