in my old car i had a 400w amp which powered very freaken well, awesome bass out of a shitty xplod sub. it ran strong for 4yrs till i sold the car.
one of their decks were a factory release into a european car, im not sure which one though.
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2619040
IMHO Blaupunkt are a good quality brand.
My headunit is a Blaupunkt florida which i bought second hand in 2000 from Cash Converters for $200 and its still in my car now, working perfectly. Looks better than all those other crap head units out their with their flashy LCD animations and all that...
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2627166
I would have rated Blaupunkt as pretty good? From what research I was doing, they have a fairly good reputation.
They make some of the "high" end stuff for stock model cars. By aftermarket standards the stock units wouldn't compare... but the aftermarket universal head units and stuff like that apparently are pretty good!
Now... Chris will shoot us all down! ;o)
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2629507
nah. I'll second the OEM comment though. considering I bought a new combo van and I have no intent of swapping the OEM unit in it (whick is blau.)
the top end gear is great! not flashy as some would like but when it comes to sound - damn good for price.
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2630013
So that's pretty much what i've been hearing.
I was actually shopping for a Blaupunkt HU when I bought my Skyline, but even eBay had diddly-squat in the way of variety/availability.
Ended up with a Kenwood 5029 something-or-other. Blue lights and flashy facia.
Well, thanks for the input, Chris!
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2632901
no probs.
blau went back to the specialist only so you wont find a lot of it on ebay.
that said if you wanted a kenwood unit at the time you should have asked me ( I also sell kenwood.)
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2633052
Chris: cheers for the heads up. I bought the unit about 1.5 years ago now, and didn't know your trade back then =-]
I didn't WANT a Kenwood. But out of the lot it seemed the least flashy, the easiest to press buttons and read display, and had some other features I had to have.
https://www.sau.com.au/forums/topic/140393-blaupunkt/#findComment-2637984
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
