Hi Guys,
I know this may have been covered before, but ive seen a few threads about respraying cars so i figured i should ask.
Just want some opinions from everyone on Midnight Purple III (LX0) paint.
I will be respraying my car soon and im really interested in getting this colour as its not only rare but also looks good.
Has anyone seen it in real? If so, what would you rate it?
Thanks guys.
https://www.sau.com.au/forums/topic/140441-midnight-purple-iii/
Most dark colours are hard to keep clean.
My old 180 was midnight purple. Looked great, and it's my favourite colour on a car, but yeah, was a bit of a bltch to keep clean.
:laugh: I kinda figured it would, but nothing is as much of a bitch as black. Correct me if i'm wrong but i think it wouldn't be as bad as black.
be prepared for $400 a litre coz i was guna get my car painted that colour bout 6months ago, out of my bugget so i get went midnight purple
:D Dont worry i'm prepared $400 is peanuts if you're happy with what you're getting. I guess you get what you pay for, true?
Is this color just a spray on a couple coats then a few of clear? Or is it a paint 1 color then another or what? How hard is it to come by the tinters?
Nick
Cant exactly answer that question as i dont know myself.. Anyone know?
its a chromilousion (spelling) colour i went to prinz paints in bayswater (only place i could find it) and its got bout 5 or more different colours in it. i cant exactly rememba, just give em a call and they'll explain the whole thing
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
