Hey Shaddy,
Havn't spoken to you for ages. Looks like the engine rebuild is still going..... how many months now??? 4? sheesh.... how much faster do you want your car to go? it was fast enough..
Hey man yeh about 4 i keep running out of money,won't be long now mate then i'll have to run the sucker in.
changed my air filter to a better one? haha. thats about it. im lookin at getting a turbo, already spent a fair bit on my car and dont wanna spend anymore until ive sold it. :)
yea, best not to spend money on a car if u planning on selling to trade up anyway. its just a waste really.
sooon, i hope lol i just got new clutch to get put in this week, so il get that installed soon, then il have to wait till after jambo, need money for that weekend before i start saving for future mods.
i also have a shift light installed.. that counts as my mod too..LOL
i'll see you at the Jambo,. come watch 17DIS down the 1/4 mile... entering the street series.. should be fun.
yeah man will come say hello for sure, going down with mates form brisbane.
if anyone want to go and see 17dis run at it. we are going to willowbank raceway on the 8-8-07. was gonna take my car but then thought (save some dignity). i will be going with 17dis, however will prob have to pull out from uni obligations.
if anyone wants to come, meet at etamogah pub at 3pm. leaving at 3.15, no exceptions, if ur not there try to catch up.
:PBJ: :P
Edited by r33cruiser
:PBJ: >_<
does that mean you're coming along now ? dude,. seriously.. take your car down for a run,. its all about the fun bro. :sorcerer:
1/4 mile run is where its at.
Looks like I ain't drivin anywhere this weekend now... just jumped in my car, doesnt kick over.
The battery is fine, there are lights on in the car...
Starter motor?
I had the altenator repaired maybe nearly 2 months ago cause it wouldnt start, im thinking that the Alarm System is draining it... not installed correctly?
Never had these problems before i had the Viper ALarm System.
thoughts?
Sounds like you are having the same problem as my brother...
Ok...deal is...Lights will turn on, stereo will work, hazard lights etc....your battery just doesnt have enough charge to kick the motor over...your battery doesnt have enough charge to do this and needs replacing...
I'd say your security alarm is draining the battery to much and your alternator has shat itself again..
Chris
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
