u 2 would look mad hot in the porka, josh with his aviators on and his long blonde locks blowing in the wind, and adam arm out the sun roof waving at all the passers by lol
I dont wear aviators :)
I have big "Naughty Corey" style glasses, but white :P
That all depends on how many times you saw me go past..
The time I saw you, I was heading to Mdore
yeah that was the only time i saw u, some fag made me drag all his 52 ceiling battens up to top level of that shops, said they were needing them coz they were gonna be on site but when i got there they were no where to be seen. so i wa slike f**k it il do it myself.
Yeh - Peregain, town of the lazy.
Everyone turns up when they feel like it :P
hey josh, u seen that HZ kingswood up north area, has full purple paint job and white interior and chromies, and has plates "51KHZ" what a pimp mobile.
Yeh thats Matt's. He had the blue soarer with the big single turbo and drift king stickers.
It's ok, has a VN 5.0lt in it or something.
Hey guy just a quick question from your experiance what do you think i should do?
i have just bought a FMIC fixed up the exhaust and need to know what to do now?
i want to take the boost up to around 10 to 11 psi and so i will have to upgrade the ECU or buy a piggy back
i want to get up around the 200rwkw mark eventually.
What do you think?
u take that thing past 10psi on stock ecu....be prepared to hit R&R.
a simple apexi safc will get u to 200kw.
argh ok i remember that soarer used to see it round coolum heaps, that kinga looks ok, but one thing i would do is put some spoker rims on it daytons would finish it off better then those rims they just dont suit it.
Rest and relaxation? lol seriously why wouldnt stocko computer handle around 10-12psi? with supporting mods like fmic and boost controller?
rich and retard. mods + stock ecu= rich.
u push past 10psi, the ecu retards timing and dumps fuel= 1 huge flat spot in rev range
http://www.skylinesaustralia.com/forums/R3...;hl=rich+retard
Edited by r33cruiser
if u install your fmic, and get a boost controller your standard ecu should be able to handle 10 -12psi no problems, probably up to like 14-15psi im sure. with out any other mods. ecu is only better when u are going larger turbo then u need bigger injectors, and fuel pump etc then ecu to manage all that stuff. unless u are going to do that in the near future i wouldnt waste your money on a ecu at this stage.
Thanks Heaps for that what EBC would you guys recommend?
ok fair enough, i though u were meaning rev limiter or something, i couldnt think what r&r was lol that why i said rest and relaxation lol
but u can still do it, ecu can handle it
well i have an apexi avcr controller, they are pretty good, lots of guy use them on skylines. or just go a blitz one or greddy profec b style or somehting similar its up to u how much u wanna spend really
Edited by 85URK
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
