u 2 would look mad hot in the porka, josh with his aviators on and his long blonde locks blowing in the wind, and adam arm out the sun roof waving at all the passers by lol
I dont wear aviators :)
I have big "Naughty Corey" style glasses, but white :P
That all depends on how many times you saw me go past..
The time I saw you, I was heading to Mdore
yeah that was the only time i saw u, some fag made me drag all his 52 ceiling battens up to top level of that shops, said they were needing them coz they were gonna be on site but when i got there they were no where to be seen. so i wa slike f**k it il do it myself.
Yeh - Peregain, town of the lazy.
Everyone turns up when they feel like it :P
hey josh, u seen that HZ kingswood up north area, has full purple paint job and white interior and chromies, and has plates "51KHZ" what a pimp mobile.
Yeh thats Matt's. He had the blue soarer with the big single turbo and drift king stickers.
It's ok, has a VN 5.0lt in it or something.
Hey guy just a quick question from your experiance what do you think i should do?
i have just bought a FMIC fixed up the exhaust and need to know what to do now?
i want to take the boost up to around 10 to 11 psi and so i will have to upgrade the ECU or buy a piggy back
i want to get up around the 200rwkw mark eventually.
What do you think?
u take that thing past 10psi on stock ecu....be prepared to hit R&R.
a simple apexi safc will get u to 200kw.
argh ok i remember that soarer used to see it round coolum heaps, that kinga looks ok, but one thing i would do is put some spoker rims on it daytons would finish it off better then those rims they just dont suit it.
Rest and relaxation? lol seriously why wouldnt stocko computer handle around 10-12psi? with supporting mods like fmic and boost controller?
rich and retard. mods + stock ecu= rich.
u push past 10psi, the ecu retards timing and dumps fuel= 1 huge flat spot in rev range
http://www.skylinesaustralia.com/forums/R3...;hl=rich+retard
Edited by r33cruiser
if u install your fmic, and get a boost controller your standard ecu should be able to handle 10 -12psi no problems, probably up to like 14-15psi im sure. with out any other mods. ecu is only better when u are going larger turbo then u need bigger injectors, and fuel pump etc then ecu to manage all that stuff. unless u are going to do that in the near future i wouldnt waste your money on a ecu at this stage.
Thanks Heaps for that what EBC would you guys recommend?
ok fair enough, i though u were meaning rev limiter or something, i couldnt think what r&r was lol that why i said rest and relaxation lol
but u can still do it, ecu can handle it
well i have an apexi avcr controller, they are pretty good, lots of guy use them on skylines. or just go a blitz one or greddy profec b style or somehting similar its up to u how much u wanna spend really
Edited by 85URK
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
