jeeez take it easy, just trying to help out.
Marty does the work himself, he has no help ,thats probably why it would take him longer to do a clutch for a skyline.Have you ever lifted or fitted a R33 or 34 gearbox by yourself or? They aint light i tell you.
Just a bit of food for thought.
Thats fine If you happy with your guy you should stay with him. Its hard to find someone you can trust these days.
As far as the job its self goes, I do know a thing or 2. done about 25 - 30 of them by my self (with a gearbox jack tho) in the past couple of years.
hope it all turns out good for ya is all.
Hey Chris, when's the 180 back from paint?
The painter said that it might of been ready today but i knew it wouldnt. At this stage mid next week.Im not in a rush for it as i want a great job, but at the same time im hanging to put it back together.
took me ages to reply on here lol. who are the skyline crew that sit up on alex hill every now and then? i can mainly remember a silver 33 a red 32 without a wing. im in the white 33 wha13.
do i know you 85urk lol have we ever met?
um, no not officially i dont think, im darren anyway. i was pulled up at 711 one night across from macca's when your car was there but i didnt get to meet you. anyway usually am at 711 servo on sunday arvo's chatting with a few mates. seen u drive by yesterday.
he has a f**ken sweet white silvia with a black vented bonnet with clear tail lights, r31, orange 180 and a few lines all in the same shed.
also has this big yank tank thing....very nice.
Edited by r33cruiser
oh ok cool as do you drive a liner? if so what colour and shit come say hey next time dude. I think the skyline boys on the coast should call themselves l1n3r b0i5
um i own the white r33 with plates 85URK? u seen it round. i even saw you today in your car down wises rd but i was in work car.
i saw your car today 85urk at where your work probably is. what is ur name man? yeh marty is working on nealy everyones now he may need to hire more people lol. i am seeing him tomoz about my belts and some other shit to clear my defect.
The silvia has a white vented bonnet, not a black one and the yank tank is called a lincoln with a ford 400 cubic inch V8 in it, both cars arent his, but yes you are right they are sweet.
Who's silver R33 with a by the looks of things with a decent gt3540 on it also there.?Must have at least 350kw....... ;)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
