Do you have any form of aftermarket CDI? eg HKS Twin power?
If it is indeed your alternator then it's not a massive job, though i've never had one fail personally its bound to go through enough wear and tear to eventually give up.
yeh but wouldnt that like turn the car off... make me loose lighting and make my headunit play up aswell??
or is there like a seperate part which runs to the ecu..
most of the times the battery light will come on, on the dash, or it will have a loud wurr to it... and the charge rate will drop to battery voltate eg. 12.6 or 12.8. if diodes are gone charge rate my be normal but untill you put lights ect on, will drop down to 13v or something... never realy seen one have any problems with supplying spark, cuz if it gets spark ecu is doing its job... how well known is your mechanic? as might be time to change... never seen an alternator do anything like what your sayen on any car.. weather it be ford, holden, nissan, subaru, mazada, ect..
i had the same symptom you have when i had my air flow meter disconnected, only as i had to get home, only with the airflow meter hooked up, it cut out and ran like shit.... my problem was that my engine was farked after it was majorly overheated but ran fine 70% of the time rb25det s2 though? dunno what yours is havent read your updates
Edited by red_screamer
hes just a normal mechanic down the road from me. not a specialist in imports or anything. I dont think its the alternator... i really dont, but he has one of those Snap-on error detector thingos, and its readying a problem with the signals to the ecu or sumshit... so im not to sure wats going on, if this doesnt solve it ill take it to marty when hes off holidays. Probably a good thing i changed the cam angle sensor anyway, its was sooooo f**ked haha both bearings where ceased and the disk and sensor where both f**ked.
i kno its so fkd. I havnt tried the ecu thing yet, would one from a rb25de neo be the same, i got a mate with a 34... or one from a rb20de?
are they all simular?
update: he said it is the alternator playing up... now i dont see how this would be the case, he recons it isnt giving enough to the computer or ecu, and that isnt able to support the igniter pack and all that... wtf?
i was checking ur gtr out today daz :rolleyes: cus my cars at yates automotive across the road there.
yeah, well im sure the ecu's are model specific, so i would try find somebody with an n/a RB25de r33/r32 (depends on what model your motor is) and try there ecu if u want to try that. but yeah unless you have diagnostic equipment to plug in, your just going to be guessing if its something more serious then all of the things i have described.
yeh the mechanic is using a snapon computer thing. If he cant fix it with this alternator thing he recons it is, im ganna go thru the elemination process on the smaller things, like loom, afm, so on as you said daz but then if im still lost ... ill take it to a specialist in this area.
i just spoke to my old boy then he went and saw my car today when i was at work.
the mechanic said when he disconnected the alternator... the missfire wasnt present... car went well, when he hooked it up there was a miss.. he said the alternator is working but having peaks of power. and the ecu is like wtf? and losses it for abit, that when the problem comes ... but stil im not convinced.
Also the miss gets smaller and smaller the warmer the car gets.. he redlined it today after it had been running for awhile, and there was a very minor misfire at like 6500.... when its cost it can rev over 1500-2000 without jerking around.
WTF i just wont this shit to fk off haha
ok legend... sorry i didn't know it was a spelling test/English lesson, next time ill be prepared for hilarious sarcasm.
Like 90% of the comments i see from you are all pathetic sarcastic calls mate. legend..
Edited by r32na
Brad!!!11!!11
Can you pm me your mobile number please?
I'm Trying to work out which turbo set up I want and I'm looking at a 3582r in .63 housing
Just wanted to talk to you as I believe you have the same set up??? And see what your thoughts on it were. :blush:
WooHoo!!!!! I got my full open bike licence today!!!! I have been out riding for about 3 hours on my cbr600 and my ass is killing me hahaha. Awesome though.
If anyone is keen for a run up the hills or something let me know!
*cough* brad *cough* :D
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
