Lol he works a street over from my workshop, i hear it all the time. I infact ran into old mate at bp whilst Kails and i were filling the 32 up, I strolled over and asked to have a look as a mate was "raging" how quick it was. I said "whats the knock mate?" he told me it was shims so i asked if it was a Neo 34 Motor to his reply "i dunno" series 2? "i dunno" how much power do you make "i dunno".... now my reply " Bro 33's dont have solid lifters, no shims there ... its your big ends. Dont rape it to much, Cya"
thanks, i dont have shims (never pulled a rb apart so i got no idear i just ashumed thay were like rb26 ) and im gessing i got close to 250kw atw at the moment ok. its not big ends, its something in the head.
No shims in a rb25. They are hydraulic lifters. Might have a collapsed one from having incorrect oil flow restrictors in place. If you drive it hard does it get better for a little bit? Unless its had a rb25 neo head or solid lifter conversion that is.
yer it dose seem to fix it up a little bit when ya rev it., oil presher dose not change once its fully warmed up.
Ok update on tomorrow morning Cuzz cant make it but we will still do a run over the local circuit so meet at 9 at the Landsborough BP if anyone cant make it let me no my number is 0421945003. We may also do a Sunday night run as well if anyone is interested in that
sigh, sometimes im glad i dont come on here much.... anyone know of any pootrols for sale there mates wanna get rid of?
i saw GQ LWB up noosa way with big muddies and raised like 3", it was up for sale for like $4500, was near the tyrepower up there i think some one who either works there or around there ows it. looked like it had all the goods on it, not a bad price.
Sorry bout that. Had something important come up.
Will definately be organising one for this weekend coming, the 3rd or 4th. New tune, woot. Those that have my number let me know if your keen, if you dont, then pm me for an invite.
sic. where the hell are they. i wish i could come with ya, sounds like fun. it keeps me up at night thinking what that thing of yours has got lol
Why does your sig say you gotta love open wastegate. yours is plumbed in, I hear it everyday.
Oh btw lads look out for a few cheeky coppers in an aurion, they know there shit. Subsequently 32 is impounded!
nugg33 if your going to drive around like a twat in kunda park industrial estate at least make a decent effort at it you shouldn't even be doing stupid shit on the street so do it somewhere else! and yes that was my boyfriend that just abused you
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
