To be honest while i love the rb motors...you cant go past the fact the 1j and 2j have more potential, without having to replace more.
lol your a mechanic work its out :P
you might want to actually back up your statements on here before making up such bullshit.
but please do tell us how you did come to a conclusion the 1j engine is somewhat a better engine then the rb26?
and do remember... your talking to people who know somewhat 10x more about this kinda stuff then you do.
what is with you and getting a kick out of searching this thread for my posts? seriously dude...get a life much?
And if you so called know 10x as much as me about these cars then you should know that the 1j and 2j have more power at the engine then what a rb engine does when it has stock internals.
Comparing power to anything but the engine is stupid because they come from cars with different set ups the closet you can go is the RB25 and the 1j seeing that they are the same displacement and both drive RW drive car, the closet you can go to comparing the rb26 to is the 2j which in that case has completely lost.
I am NOT referring to a fully modified engine, and the first statement you quoted was in fact referring to the 1j against the rb25 as at that stage there was no mention on a rb26 at that stage in my posts.
If you didn't know that i suggest pulling you head out of the dark psychotic midst its in, shutting your mouth and do something good for yourself and research.
plus a person who knows 10x more about cars then myself, would know how to not blow a RB26 engine.
That is all i am going to say in reply to this and if you wish to take this further email me.
Edited by 000DNK
since this "person" replying knows so much about the rb26, you'd know by fault that the big end bearings go within the rb26 engines hence they blow easy. bawahahahahahaha
90% of rb26 engines are rebuilt because of the big end bearings otherwise they are modified before they blow.
btw, i read through this thread daily.
just found what you posted to be funny.
Another reason why the 1jz and 2jz have more potential without having to replace more as i first stated :bunny:
i would also appreciate if you would cut the language out as there is no need for it and i do find it quite offensive.
Edited by 000DNK
LOL!!!!
The 2jzhas the potential to anything like any engine but at the same time, it still needs modifications done just like any other engine to get its power figure. a rb26/30 has the ability to produce something of the same power a 2jz engine does.
LOL
you need to do some more researching.
just been reading though this, and i noticed a comment "ohh and btw... the gearboxes in the 2jz and 1jz can't handle the power figur a rb25 can handle" quoted by Jjay, believe it or not the R154 can handle in excess of 500rwhp without a single modification, and the V160 and V161 supra 6 speed boxes don't need to be modified until 850+ rwhp, whereas the humble RB25 gearbox will start throwing 1st and second gear at about 400rwhp. back to the drawing board i think. my 2c worth
Farrk me what a shit fight...here we go again.
JJay and Andrew, both w58 and r154 toyota gearboxes have there issues, and so do Rb25 gearboxes,It goes to how you treat them,(flat changing is not really good for any gearbox for that matter) not necessarily how much power you are putting in front of them BUT how much torque , you know the stuff that makes your engine twist when you blip the throttle on idle??
You can run way more than 400hp on a rb25 gearbox...Many of you may not know that they have the same bearing diameters as GTR gearboxes, but with less grip of a 4wd car they are quite strong in a rear wheel drive car.
A Rb25 gearbox is basically the same as a GTR box but without the transfer case.
The Toyota boxes aren't too bad either, but they tend to get a broken washer or shim in them which causes gearbox to jam, a factory fault i believe but makes it worse even with minor hp increases .
The Getrag 6 speed is the ducks nuts for toyotas, can withstand coupious amounts of torque and power, but once again how you treat it is a major factor.
So anyone going to the track day on saturday at willowbank? I am but not racing,
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
