haha cheers roger. always have to be careful with a screamer=illegal. finally good to c u and ur car in person after all these months.
lol, guys i just got this from a mate u HAVE TO C THIS.
http://www.youtube.com/watch?v=kHmvkRoEowc
and markimak when ur up put up a post, so we know where u are and stuff
for sure mate im staying at the northpine camp grounds next to alma park zoo. from next friday to the saturday after so a good 8 days.. be going coast a few times and go karting at big kart track think tuesday.. unsure yet :P
whats the bruce highway like at midnight :unsure:
and btw that video was slightly gay i laughed soo much
for sure mate im staying at the northpine camp grounds next to alma park zoo. from next friday to the saturday after so a good 8 days.. be going coast a few times and go karting at big kart track think tuesday.. unsure yet :D
whats the bruce highway like at midnight :D
lol, thought u would like, what a fag=WANT TO PUNCH HIM SOO BAD.
the bruce, is pretty clear, we use (whispers) 'detection equipment'. :D
never had any probs, but if u run into something
DO-NOT-STOP. there are heaps of off roads and hiding places.
the bruce, is pretty clear, we use (whispers) 'detection equipment'. :P
:( Remove your post [email protected] not very smart.. Use a pm for that man.. Not being mean, just be mindful that anyone can read these forums.
Cheers.
just stay off boost you'll be fine... but yeah,. nice to meet you too mate.
next time we should organise a photoshoot,.. maybe next thusrday nite hey.
darkness are u buying a flame thrower? say it aint so
all u need is a bit of 98ron and some revs = flames.
if mine can do it without a flamie. ur new gtst will.
dont bother, but would be a cool party trick to do by the flick of a switch
while im up wher u boys are.. from this friday till sat week. what should i do up ther when im bored..?? im going big karts go karting on tuesday arvo.. is ther any nice beaches and stuff..?? car meets yada yada.. im staying close to alma park zoo off the bruce highway..
if ur a surfer, alex is the best, maroochy is good, but really blown out. if u were here 1wk ago we had solid 4ft of peeling left swell, but u MISSED IT ;)
pretty much the meets happen on thursedays so u will only be here for one. :laugh:
-friday night is good for a cruz, but this is when all the ricers come out=increase cop activity.
-but on saterday there is a bit going on. marki maximus since ur a drifter, we can hook you up with some touge runs etc.
-there is also a huge v8 and 400+HP only car show/meet. but that only happens on the first thursday of each month called HUMBLE PIE.
-sunday from 2pm onwards is a general cruising time.
but other than that there isnt much car action going on, we dont have a track as yet. but counciller chris MUST take care of that
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
