Hi All,
You've probably read my other stupid post about me hooking up the fuel lines backwards and "thinking" that the place who cleaned my injectors fried them.... Anyhow I've assembled the fuel rail, plenum, throttle body with new seals and gaskets... And the car starts.
The Good News
I've noticed it starts easier, plus idles much nicer with no idle hunting and also the motor is heaps more quiet.
The Bad News
Feels like the car is 2x slower than before, I can't feel the kick when the boost hits. I've checked for leaky vaccuum lines & other air lines that go to the AAC, etc... no leaks... and the boost still registers 12PSI..
What is going on?
So in your opinion, you think it's running more rich?
that is fairly common from what i have seen , that cleaning your injectors allows them to flow more ..
flowing more for any given pulse of the injectors would mean that more fuel per pulse, which would be more rich, as the ECU doesnt know how much its flowing, only how long its pulse is.
so yes, it would be running more rich
I'd say get some management as Chris said :laugh:
You've hd it running leaner than normal... now its just running as normal and needs to be leaned out again in the correct fashion.
See how it goes after that... shouldnt be an issue i reckon
But leaning out is asking for trouble right?
Well I might get a re-map done again on my ECU and see how I go from there....
just get a quick recheck of the AFR's ona dyno
if they are good now, means they were bad before.
You probably should reset your ECU after cleaning the injectors so it can re-learn the set up. It can take a couple hundred kays to settle in.
Also it could be that you were actually running closer to normal AFR's because the injectors were dirty. The actual reason could be that the O2 sensor is kaput & the system is running over rich because of it.
Look for lots of black crap on the bumper around the exhaust after a weeks worth of driving, a good indication it's over-rich.
Edited by JazzaR33
It's not running rich, my bumper isn't that dirty...
I think what Craved said was correct, because my injectors were so dirty the car was leaning out hence giving out more power...
I'll throw is on the dyno when I got money, so broke now
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
