But if you are planning on sticking with the std turbo....i would be very interested to see an engine that actually has more mid out of it. Does anyon ehave graphs of before and after?
Even with NickR33s results...im not convinced. The std turbo isnt that big for a 2.5L and i doubt they can provide the airflow to really need cams to help fill the lungs.
If NickR33 picked up some grunt...i woudl then ask did he have the SAFC tuned before the cams were installed?
Not being argumentative, just curious to see if we can rule out some other things :P
I used to have a before and after graph, it was about 15-20hp up in the mid range. The top end was improved also but, without access to the timing maps (S-AFC II) the top end had to be left alone.
I picked the HKS exhaust cam as it was spec wise pretty close to some advice I got from someone in the cam making game.
Ok, thats interesting then. I know of a few examples that did nothing with cams. One i read about and another was a friends R34GTT which actually lost power with the std turbo. It wasnt until he got the high flow goign that it shined.
Perhaps there is more to it, i stand corrected :P
No Roy,
You are right about over-caming the motor ,the main issue is going over the top on the inlet side with such a small turbo. The R34 Neo motors have a better profile set of solid cams than the hydro- R33 ones.
I used step 1 HKS 264deg 9mm lift exhaust cam and the factory inlet.
Hey,
Cams are good, especially poncams which do not need heavier spring, valves, or having an aftermarket computer in.The Poncams are designed to bolt on and drive off...not even cam gears are needed.0 adjustment works the best for them.
If this is the only modification you are planning in the next year or so ...do it because you will get great results.
Hope I have been of some help..
Cheers :P
These cams are around $800 for the set and installation should be around $400.
Your power output will increase slightly, but your response and power curve will be alot better.
Where do you get poncams for $800?
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
