I've thought about getting it done too, because the rest of my stuff has blue lights in it...
Ages ago when the nokia 8210's were around, then the 8250 came out, people were getting their 8210 lights changed to the blue LED's from the 8250...
An asian guy at the laverton market did it for like $50 at the time (very tedious work if you've seen the size of the LED's)...If he's still there, i'd say he'd be able to do the same for the pfc hand controller, because the LED's look very similar if not the same.
  • 1 year later...
hey jono
nah its not in there - i can dig it up, ive still got the hand controller in my room
from memory the wires are brown and white which you run to + and - on the USB plug / loom
it lights up but wont boot - unsure if this will damage the hand controller or not as the one i was testing with was toast before i started
hey jono
powering it up without a signal won't hurt it.
Mine is fine, I just need it to power with a logo, so I can sit at my desk and test some things to solder it up so the back lights start working properly again.
Its too hard to plug into the powerfc in the car and try and solder it there
