Gcg Or Kkr Turbo?
Guest Rotary20B
in all fairness you can't really say the kkr turbos are bad.
sure they'll work and give you some good performance but the fact of the matter is they won't match the performance and reliability of a gcg bb turbo
So the KKRs aren't reliable?
I have read of a few good reports about them, but wanted to get peoples first hand experience.
As for performance, they are actually better than the GCG which is the reason I am looking at them. apart from them being non bb that is, which doesn't bother me one bit.
Relibility is an issue though if you know something.
theres 5 main things that come to mind when we talk about bb vs non bb
1) price difference
ball bearing units are often more expensive. they are expensive for the obvious reason, they are better. but presumably it comes down to balancing the unit possibly different and/or using different equipment / skill in the engineer lab to build bb units
2) spool up or "response"
with non ball bearing it will take longer to spool up
theres a graph floating a round somewhere of bb vs non bb spool up
i think it was about 2 second different in turbine speed response for bb vs non bb.
3) failure rate
another issue of non bb is theres a chance of bearing failure when the oil feed is cut off and the bearings are hot. that is if you go for a hard run, and instantly cut the engine off / oil feed. bb have a greater tolerance to heat, whereas the plain / journal brothers do not and can fail. ie if you are doing a run and say stall the car or have to turn it off, say cops pull u over or something.
4) oil feed changes
for plain / journal bearings the oil feed needs to be modified to flow more oil into the bearings. they need more oil to keep the flowing and lubed up. bb need less oil so they have a restrictor in the oil line by default. with the journal / plain brothers you need to usually remove the restrictor and or make the oil line bigger / better to flow more oil.
5) oil lifespan
as the bearings need more oil flow into them, they go through more oil, that is more oil is pushed through the bearing core to keep it happy and lubed. so your engine oil is "used" at a faster / higher rate than the same engine with a bb turbo unit. im not sure what this means in terms of oil life span in your engine but say bb oil change are every 10,000 you may be to changing it every 7000 k's (guesstimation) if using journal / plain bearing units
so there are a few considerations to take into account. hopefully some of the info ive provided may help you make a descision as there are pro's and con's for both bb units and non bb units. we notice that oem manufacturers (well at least we think they do) prefer bb units over non bb units for things such as reliability, longer life span, better oil lifespan, better response and less km's between rebuilding them. if any of the info ive provied is wrong please let me know and ill correct it. the more we all learn the better it is for all of us
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
