Ok, I couldn't find anything of value so I thought I would ask how the T70 turbo's go with an RB25 motor?
.82 exhaust size with a 60.5mm front wheel is the one I am looking at.
I am ok with a little lag, ie it starts boosting at 3500rpm.
but do they come on at 5k or something ridiculous?
Not after opinions on the quality of a T70, just what they are like on a 25 please.
https://www.sau.com.au/forums/topic/140893-t70/
My mate one tuned one for a customer rb25det and it made 420rwhp on 19 psi. it made full boost at around 4000rpm
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624026
that's the answer I was hoping for.
have got 550cc injectors, haltech ecu etc etc, so I figure if I see full boost by 4k and I am making high 200rwkw's, they must be a good "cheaper" turbo then.
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624032
420rwhp is about 300rwkw :sick:
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624074
assumptions?
Why do you think I am asking the question here?
Got an answer that relates to an answer I got elsewhere that they are pretty good on a 25, but laggy on a 20.
The 20 I speak of made 24orwkw on 19psi.
I plan on running 16psi in the 25 and anything between 250-300 rwkw will be a big jump from 204rwkw that I had last tune.
Saying that, it's more a question about lag.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624080
yep thats right boosting at 4800, i had power fc, the usuals no internals, too get it to boost early like 4k you would need a good set of cams. and im now running a gt3040. your better to save your money and do the job right first than waste $500 or however much they are, i learnt the hard way money down the drain and i had a lag monster.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624094
gt3040 or a gt3540, is a million times better. you can choose your ex. housing size for your response you want. there excellent quality, ball bearing, water cooled. i really wish i went that to start with instead of trying to get cheap power that just cost more in the end.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624119
I had one also on my rb25 and didnt see full boost till about 4800-5000rpm...was a mass lag monster. On 17psi i made 350rwhp with supporting mods and all, no cams though.
then it ceased up cause the shitty oil line i used got blocked up and starved the turbo of oil.
Now have a gt3040 with .63 rear, much much better :)
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624947
i got a friend who has one of these t70 turbo's off ebay..its making around 293rwkw @ 18psi,bit of a lagg monster but once it comes it comes on HARD..has been for last 5months..never missed a beat..i dont understand how u guys break them so easily?
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2627344
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
