Hi all
My current rims have a chrome lip, and due to brake dust there has been some slight tarnishing/patchiness/staining and build up of guk on the bits of the chrome.
I can kinda scratch it off with my finger nails, and in some sections, it just looks a bit tarnished.
Tried some light polish, some meguiars products, nothing can get it off.
I am guessing its due to the brake dust because the rear wheels are completely fine, just the front rims.
It kinda looks like water marks and is not as smooth when you run your finger over the chrome lip.
Any suggestions on what I can do?
Thanks all
Edited by nuffsaid
i read somewhere about this. there really isnt anything you can do apart from getting your rims resprayed to look like new again. the best thing to do is when you have new rims is regularly clean them because its the dirt and brake dust that damages them
metho will remove the staining, but if you want to give it a go, be EXTREMELY careful and make sure you don't get any on the tyres. Put the metho on a rag, apply it directly to the stained areas and rub.
*Disclaimer: If your tyres melt, i won't take responsibility for it! :thumbsup:
If you want to try something a bit safer, have a go with some autosol.
if it's chrome, spirits shouldn't dull the finish, if you're scared of scratches, make sure you get any surface grit off first.
If you have the slightest concern about using spirits near the rubber, then try autosol first
if you can't find autosol (or don't want to spend money on something that might not work) go and raid the kitchen.
vinegar and bicarb is a very user friendly (and enviro friendly) combination for any cleaning task!
Pics of before and after?
I have this problem with one of my sets, the worst part is, the national electroplating union says no one in Oz does car wheel dipping, heaps do trucks, but none to car rims....
I put some Meguiars paint cleaner on it yesterday and rubbed the hell out of it with a terry towel. Seems to have cleared up most of the problem.
Also scratched off the really stubborn bits with my finger nail heheh
Anyone have any other good tricks?
depending on the type of chrome you have.. if it's not high quality take care not to use any abrasive products like Autosol or cutting creams... at this stage you'll need lots of elbow grease and WINDEX... and use a cotton cloth like an old T-shirt.
Yeah I think I may have already slightly scratched it, its not really noticeable anyway so I am not too fussed.
I waxed the chrome part of the rim so that the brake dust should come off easier next time.
Alot of elbow grease went into it last nite, most of it seemed to have come off.
The chrome feels very plastic-ky though, not like solid metal. seems as if there is a clearcoat on them
my point exactly..try not to let the dust build up...if it's black dust maybe you should consider changing your brake pads to Bendix Ultimates as the dust is "white" and not as harsh on chrome.
Its brown dust, that usually, if i wash my wheels once a week, comes off really easily. Problem is this time I left it on to bake too long.
My Formula Ferodo pads are just way too dusty for me, maybe on par with Ultimates, but they give off a brownish dust which is the adhesive compound in the pad material moreso than metal filings.
I have given up on finding performance pads with low dust, i think its like asking for good tyres that last a long time.
Many mag manufacturers have total control over their products, which means that some multi piece rims can't be disassembled by anyone other than the manufacturer.
If this is the case with the brand mags that you have, the only option is to send them back to the manufacturer for repair/restoration work.
However, unless the finish on the plating has somehow been compromised, they wouldn't need to be re-plated.
There are heaps of places that specialise in mag wheel polishing/restoration, but after having a quick look, I couldn't find any local to you. :)
Thanks for that mate ;)
yeah i spent a day ringing every place in Australia, no one will do them back to how they are now :O
All i can do for them, is have them polished and the middles sprayed with black (powdercoat), but thats a fair bit of hassle, i think its time for them to go
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
