I got few r34 gtr body parts!!!
one blue front bumper 350, one yellow front bumper 300
2 left fender (more wide than r34 gtt's) 300 each
one gtr nur carbon firbe bonnet, one crack on it, i want 800, if no crack on it, its value more than 3000
i am in brisbane, except these parts, i also can import any parts from jap for u.
if anyone want buy whole r34 gtr front end, i can give u discount, let me know asap, if no one want it, i will install to my own car.
they are in good condition except that bonnet
cheers
Edited by SUGO
https://www.sau.com.au/forums/topic/141046-r34-gtr-front-end-parts/
  • 1 year later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
